Date/Time: Wed, 25 Nov 2026 21:56:20 +0000
Connection Issue (Dec.18, 2025)
View Count: 600
[2025-12-18 15:53:15]
Tony - Posts: 738
I have experienced connection issue multiple times this morning, (chart window showing, downloading data) which never happened before. I am using Denali and Rithmic.
Not sure if anybody else has the same issue?
Date Time Of Last Edit: 2025-12-18 15:53:30
[2025-12-18 16:18:26]
User135243 - Posts: 337
works fine all day long, I guess a problem on your end
[2025-12-18 16:55:46]
You can get us your Message Log and we can take a look and see if there is anything specific in it. Follow these instructions to get us the log:
[2025-12-18 17:30:33]
Tony - Posts: 738
Thanks John! I accidentally closed Sierra earlier, I will keep an eye on it tomorrow, if it happens again, I will post a Message Log.
[2025-12-18 18:21:37]
Tony - Posts: 738
Hi John,
It happened again just now, I copied and pasted the message log below, thanks so much.
2025-12-18 09:54:07.271 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Chicago Area-Aggregated
2025-12-18 09:54:07.271 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50503
2025-12-18 09:54:07.271 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50503
2025-12-18 09:54:07.376 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-12-18 09:54:07.377 | DTC Client socket (3) | New receive buffer size: 5242880
2025-12-18 09:54:07.377 | DTC Client socket (3) | Connecting to IP: 216.57.156.163.
2025-12-18 09:54:07.466 | Rithmic Direct - DTC | Network connection to server complete.
2025-12-18 09:54:07.466 | Rithmic Direct - DTC | Starting socket receive thread.
2025-12-18 09:54:07.466 | Rithmic Direct - DTC | Using fixed encoding of Binary
2025-12-18 09:54:07.466 | Rithmic Direct - DTC | Sending logon request message.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Received logon response.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Server Name: .
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Successfully connected.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Trading is supported.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | OCO Orders supported.
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-12-18 09:54:07.740 | Rithmic Direct - DTC | Connection to server complete.
2025-12-18 09:54:07.740 | Denali Data Feed | Waiting for socket receive thread to end
2025-12-18 09:54:07.740 | DTC Client socket (8) | CloseSocket call.
2025-12-18 09:54:07.740 | Denali Data Feed | Disconnected from the server.
2025-12-18 09:54:07.741 | DTC Client socket (8) | Shutdown started. Waiting for graceful close.
2025-12-18 09:54:07.741 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-12-18 09:54:07.741 | Updated verified funded futures trading account ending date to: 2026-01-17 17:54:07 | Number times message added: 1
2025-12-18 09:54:27.371 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Creating socket. Using TLS 1.2.
2025-12-18 09:54:27.372 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | New receive buffer size: 32768
2025-12-18 09:54:27.373 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Connecting to IP: 38.79.0.89.
2025-12-18 09:54:28.096 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | New receive buffer size: 65536
2025-12-18 09:54:28.240 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Socket gracefully closed by remote side.
2025-12-18 09:54:28.241 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 110576
2025-12-18 09:54:28.242 | Rithmic Direct - DTC | Processed connection points. Count: 474
2025-12-18 09:54:28.243 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | CloseSocket call.
2025-12-18 09:54:28.243 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-12-18 09:54:28.243 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Closed.
2025-12-18 09:56:26.605 | DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close.
2025-12-18 09:56:26.606 | DTC Client socket (6) | Closed.
2025-12-18 09:56:26.606 | DTC Client socket (8) | Timed out waiting for shutdown. Performing an immediate socket close.
2025-12-18 09:56:26.606 | DTC Client socket (8) | Closed.
2025-12-18 09:56:26.606 | DTC Client socket (6) | Socket gracefully closed by remote side.
2025-12-18 09:57:26.603 | DTC Client socket (6) | Deleting network socket now after delay.
2025-12-18 09:57:26.603 | DTC Client socket (8) | Deleting network socket now after delay.
2025-12-18 10:18:40.584 | Mapping ESH6.CME to ESH26. Service code: cme
2025-12-18 10:18:40.584 | Using symbol data fast lookup vector
2025-12-18 10:18:40.584 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 1 Service code: cme
2025-12-18 10:18:40.584 | Denali Data Feed | Connecting to the server ds27-2.sierracharts.com. Port 10048
2025-12-18 10:18:40.584 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 1
2025-12-18 10:18:40.584 | Mapping MESH6.CME to MESH26. Service code: cme
2025-12-18 10:18:40.584 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 2 Service code: cme
2025-12-18 10:18:40.584 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 2
2025-12-18 10:18:40.584 | Added historical Intraday data request for ESH6.CME to the queue.
2025-12-18 10:18:40.584 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'.
2025-12-18 10:18:40.584 | Triggering next historical data download in queue.
2025-12-18 10:18:40.590 | Delaying start of download for ESH6.CME.
2025-12-18 10:18:40.657 | DTC Client socket (5) | Creating socket.
2025-12-18 10:18:40.657 | DTC Client socket (5) | New receive buffer size: 5242880
2025-12-18 10:18:40.658 | DTC Client socket (5) | Connecting to IP: 216.200.108.155.
2025-12-18 10:18:40.745 | Denali Data Feed | Network connection to server complete.
2025-12-18 10:18:40.745 | Denali Data Feed | Starting socket receive thread.
2025-12-18 10:18:40.746 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2025-12-18 10:18:40.853 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-12-18 10:18:40.853 | Denali Data Feed | Sending logon request message.
2025-12-18 10:18:41.572 | Denali Data Feed | Received logon response.
2025-12-18 10:18:41.572 | Denali Data Feed | Server Name: SC Realtime Server.
2025-12-18 10:18:41.572 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-12-18 10:18:41.572 | Denali Data Feed | Successfully connected.
2025-12-18 10:18:41.572 | Denali Data Feed | Trading is not supported.
2025-12-18 10:18:41.572 | Denali Data Feed | MarketDepthIsSupported: 1
2025-12-18 10:18:41.572 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26
2025-12-18 10:18:41.572 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26
2025-12-18 10:18:41.915 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878
2025-12-18 10:18:41.915 | Denali Data Feed | Received security definition for symbol ESH6.CME
2025-12-18 10:18:41.915 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800
2025-12-18 10:18:41.915 | Denali Data Feed | Received security definition for symbol MESH6.CME
2025-12-18 10:18:46.820 | HD Request # 3 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme
2025-12-18 10:18:46.820 | File compression not supported on file system. C:\SierraChart\Data\ESH6.CME.scid. Windows error code 50: Request not supported.
2025-12-18 10:18:46.820 | HD Request # 3 | Download start date-time: 2025-12-18 09:54:02.000000. File last date-time: 2025-12-18 09:54:02.000000
2025-12-18 10:18:46.820 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2025-12-18 10:18:46.884 | Socket (6) | Creating socket.
2025-12-18 10:18:46.885 | Socket (6) | New receive buffer size: 5242880
2025-12-18 10:18:46.885 | Socket (6) | Connecting to IP: 69.39.70.248.
2025-12-18 10:18:47.047 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-12-18 10:18:47.047 | HD Request # 3 | Sending historical data logon request message.
2025-12-18 10:18:47.157 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-12-18 09:54:02. Record interval: 1. Symbol: ESH26
2025-12-18 10:18:47.234 | HD Request # 3 | Decompressing data.
2025-12-18 10:18:47.332 | HD Request # 3 | Receiving Intraday data for ESH6.CME starting at 2025-12-18 09:54:02.014000
2025-12-18 10:18:47.416 | Socket (6) | CloseSocket call.
2025-12-18 10:18:47.416 | Socket (6) | Shutdown started. Waiting for graceful close.
2025-12-18 10:18:47.416 | Historical data download thread signaled to stop.
2025-12-18 10:18:47.439 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-12-18 09:54:02.014000.
2025-12-18 10:18:47.439 | HD Request # 3 | Received 1449 Intraday data records from 2025-12-18 09:54:02.014000 to 2025-12-18 10:18:45.011000 (24.7 minutes. Delay: 2.4 seconds) and wrote 1449 records for ESH6.CME
2025-12-18 10:18:47.439 | File compression not supported on file system. C:\SierraChart\Data\ESH6.CME.scid. Windows error code 50: Request not supported.
2025-12-18 10:18:47.439 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-12-18 18:18:45.011000
2025-12-18 10:18:47.439 | Added 2 Time and Sales records to Intraday data file for ESH6.CME after download.
2025-12-18 10:18:47.439 | HD Request # 3 | Completion time: 1s.
2025-12-18 10:18:47.439 | HD Request # 3 | Intraday data download complete for ESH6.CME. Unique request ID: 3
2025-12-18 10:18:47.439 | Removing historical data download ID 3.
2025-12-18 10:18:47.439 | Real-time Intraday chart data file updates started for ESH6.CME
2025-12-18 10:18:47.440 | Opened cached Intraday file: C:\SierraChart\Data\ESH6.CME.scid. Thread ID: 316
2025-12-18 10:18:47.440 | Intraday chart data file opened for ESH6.CME
2025-12-18 10:18:47.440 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-12-18 10:18:47.440 | No download requests in the queue to start downloads for.
2025-12-18 10:18:47.496 | Socket (6) | Socket gracefully closed by remote side.
2025-12-18 10:18:47.496 | Socket (6) | Closed.
Date Time Of Last Edit: 2025-12-18 18:22:21
[2025-12-18 20:31:26]
What time did you have the issue? Was it right around 10:00?
[2025-12-18 20:35:58]
Tony - Posts: 738
It was around 10:18, Pacific
[2025-12-18 20:44:38]
What is interesting is these two lines:
Where there is a jump from 09:57:26.603 to 10:18:40.584. Was your computer in a Sleep or Hibernate mode at that time?
After 10:18:40.584, everything in the log looks normal, but the system is downloading missing data. Note this line:
Which means that there was some kind of connection issue from 09:54:02 until it reconnected at 10:18:47.439.
[2025-12-19 18:03:44]
Tony - Posts: 738
Hi John,
I just noticed another error message in Message Log:
"File compression not supported on file system."
I searched old support posts regarding this issue,
and set file compression to "No" now.
I have been observing the chart for a while and haven't
had the same issue yet, I will keep an eye on it, the reason
I didn't notice before is because I always practice by replaying
historical data, and just went live recently.
One thing to confirm: File compression and Real-Time Data Compression
are not related, right?
Thanks John!
Date Time Of Last Edit: 2025-12-19 18:05:02
[2025-12-19 21:06:45]
Disable file compression:
Advanced Service Settings: File Compression (Global Settings >> Advanced Service Settings)
These are unrelated:
