Date/Time: Tue, 17 Nov 2026 18:09:17 +0000
Backtesting using footprint for FTSE and EURO futures
View Count: 594
| [2025-12-17 17:17:19] |
| User874265 - Posts: 11 |
I want to back test FTSE and EURO futures. I currently have 1 year package 11 subscription ONLY. I didn't purchase any data feed. But, still can I back test without purchasing Data feed ? I search a lot for answers but always got mixed answers. So, my question is ....To back test FTSE and EURO futures using foot print chart, do I need to purchase data feed ? |
| [2025-12-17 18:50:54] |
| John - SC Support - Posts: 48555 |
With any package, you have full access to our Historical data and our Delayed Streaming Data Feed. Refer to the following: Sierra Chart Historical Data Service Delayed Exchange Data Feed Therefore, you can download whatever historical data you need/want and run the backtesting on it. We have data for EUREX, if that is what you are referring to in terms of "EURO Futures". For information on the EUREX data, refer to the following: Denali Exchange Data Feed: EUREX Data Feed Notes But we do not have data for FTSE (or other EURO Futures exchanges, if you are not referring to EUREX). To get the data for FTSE into Sierra Chart, you would need to connect to a service that has this data. In this case, you would need to be on one of the "Integrated" packages (which you are currently are with Package 11). Refer to the information at the following link: Description of Service Packages and Pricing: Integrated Packages If you do not have access to the data through your broker for FTSE, then you can check with DTN IQ Feed and see if they have the data, as we have connectivity with them. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-18 15:07:36] |
Thank you for the Guidance! When you say "Historical Data", One last question I have in mind is... Can I back test using Foot Print charts on say..3 minutes timeframe ? |
| [2025-12-18 16:32:25] |
If you look at the historical data we have available, you will see that there is tick-by-tick data available. The exact amount of time for the available data depends on the data you are wanting. Therefore, you can definitely get accurate results for a Numbers Bars chart with that tick-by-tick data, regardless of the timeframe of the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-18 16:50:31] |
Got it, Thanks! Appreciate your Prompt Response! Date Time Of Last Edit: 2025-12-18 16:56:18
| [2025-12-22 07:15:22] |
DTN IQ seems costly to me. Is there a cheaper way to get Historical Data for back testing FTSE 100 ? especially using Foot Print and Delta
Date Time Of Last Edit: 2025-12-22 08:07:40
