Date/Time: Tue, 24 Nov 2026 00:46:39 +0000
Feature Request: Native On-Chart UI Widgets (Sliders/Buttons) for Interactive Studies
View Count: 635
| [2025-12-15 15:37:08] |
| TonyCipriani - Posts: 155 |
Hello, I am developing a custom ACSIL study that requires a high-speed, interactive workflow. My goal is to adjust parameters to see results update in real-time. Currently, the workflow is bottlenecked because I must open the Study Settings window for every minor adjustment. This modal window blocks interaction with the chart until closed. I would like to request the following ACSIL capabilities: 1. Interactive On-Chart Controls (WPF-style Widgets): Is it possible to add native UI elements - specifically Sliders, Spin Buttons, or Checkboxes — directly onto the chart surface (or a docked study panel) that link directly to Study Inputs? The purpose is to adjust an input value via a slider and trigger an immediate recalculation without opening the Settings window. 2. Is there a more direct/efficient ACSIL function to implementing a "Drag-to-Select" tool that returns Start/End Bar Indices to the study immediately upon mouse release? 3. Non-Modal Settings Window: Is there a way to keep the Study Settings window open while interacting with the chart and seeing updates apply in real-time without clicking "Apply"? This functionality would significantly enhance the capability of custom interactive tools in Sierra Chart. Thanks a lot. |
| [2025-12-16 04:33:17] |
I'm so sorry, I just found a way to get #2 done; I was getting errors on ACSIL for a long-time but now got it after many months. Even for #1 and #3, the Custom Study Control Bar buttons can get the job done too which I had no idea about.
| [2025-12-16 05:01:54] |
| Sierra_Chart Engineering - Posts: 25470 |
1, 2. Refer to: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events 3. Non-Modal Settings Window: Is there a way to keep the Study Settings window open while interacting with the chart and seeing updates apply in real-time without clicking "Apply"? This is coming.Also refer to: Chart Studies: Changing Study Inputs Directly from Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-16 05:04:22
| [2026-10-24 17:36:12] |
| User719512 - Posts: 546 |
@TonyCipriani, Good idea you suggested in this post. In case you have not already found a solution for your #1, I wrote an Input Spin Control study that lets you change a study input by small, med, large increments. It supports drag/drop so you can move it where you want on the screen. Screenshot at: https://www.sierrachart.com/image.php?folder=upload3&Image=1792862601564.png Date Time Of Last Edit: 2026-10-24 19:50:26
