Date/Time: Wed, 25 Nov 2026 21:46:25 +0000
Charts not updating past old payment date
View Count: 521
| [2025-12-12 00:40:39] |
| skyewarde - Posts: 2 |
Hi, I had a one month subscription. The charts worked until Spt 20. I did not use sierra again until last week when I paid for a year subscription. but the charts are not updating to the current day of dec 11 2025. And some charts are not loading at all. What do I need to do? https://www.sierrachart.com/image.php?Image=1765499847530.png - date only loads until Sept 19 https://www.sierrachart.com/image.php?Image=1765499960952.png - charts not loading Thanks |
| [2025-12-12 00:50:23] |
| Sierra_Chart Engineering - Posts: 25483 |
There is more than one problem. First translate symbols to the current service: Edit Menu: Edit >> Translate Symbols To Current Service And make sure you are using the December futures contracts in the case of futures: Changing to a New Futures Contract Month There will be a rollover to March 2026 soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-12 14:54:11] |
Your response solved the issue. Thank you!
