Date/Time: Tue, 17 Nov 2026 18:09:05 +0000
Sierra log me out of Rithmic and NinjaTrader
View Count: 593
[2025-12-07 17:55:04]
User183034 - Posts: 3
I’m trying to use Sierra to see order flow with fottprint,
I have an account of Rithmic with Apex and I use NinjaTrader set my orders
When I connect the data/trading service with my username and password of Rithmic and click on connect, it logs me out of both Rithmic and Ninjatrader
I have allow the plugin mode on both rithmic and ninja trader but as soon as I login on Sierra chart it logs me out of the others
Would you please help me fix this problem
Date Time Of Last Edit: 2025-12-07 18:01:19
[2025-12-07 19:25:45]
Sierra_Chart Engineering - Posts: 25432
The problem you are experiencing does make sense because Sierra Chart connects directly to Rithmic servers and Rithmic only allows one connection at a time per username.
Sierra Chart does not connect to the Rithmic software running on your local system. If you just want to use Sierra Chart for charting, then the best solution is to not use Rithmic and instead follow the instructions below:
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2025-12-07 19:27:50
[2025-12-08 15:31:47]
That option is not delayed?
[2025-12-08 15:46:02]
In your case it is currently delayed but you can get real-time data. What exchanges do you want real-time data for?
Date Time Of Last Edit: 2025-12-08 15:46:09
[2025-12-08 16:06:02]
Nasdaq futures
[2025-12-08 17:12:07]
John - SC Support - Posts: 48555
If you want to get real-time data for the CME Group from our Denali Exchange Data Feed at the non-professinoal rates, then you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Prop firm accounts (like APEX) do not count towards this requirement. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Once you have the above worked out, then you can setup the data for the CME Group by following these instructions:
