Date/Time: Wed, 25 Nov 2026 21:36:02 +0000
TT Connection Rejecting NG (NYMEX) Orders – Instrument Not Found Error
View Count: 477
[2025-12-03 02:02:42]
User368741 - Posts: 106
I’m unable to place orders for NG on CME (NYMEX) using the TT connection. The orders are getting rejected and Sierra Chart is showing the following message:
“TT Futures Order Routing (Order reject). Info: TT order update (Rejected). Text: TT FIX: [Instrument not found by NAME=NGF6 symbol=NG7]SecurityAltID = NGF6, SecurityAltIDSource = 98. Text: Parent order”
Can you please check why these NG futures orders are not passing through and confirm if there is a configuration or symbol mapping issue?
[2025-12-03 04:08:13]
We did some checking, and we do not notice any obvious problem. We think we have the right symbol (just simply NG) but maybe there is some different symbol that TT uses for natural gas?
[2025-12-03 05:31:07]
no the symbol is NG on TT
[2025-12-03 05:35:59]
I have attached a screenshot of the error message for reference
imageScreenshot 2025-12-03 053446.png / V - Attached On 2025-12-03 05:35:09 UTC - Size: 7.15 KB - 195 views
[2025-12-03 18:00:57]
This is the symbol mapping that exists:
<symbol>NG?##_FUT_NYMEX</symbol>
<external-service-symbol>NG?#_NG_FUT_CME</external-service-symbol>
The external service symbol, is separated at each part where there is an _. Those four components, are sent to TT in the FIX message. They are set into the appropriate fields. This is just like any other symbol. So why there is a problem we do not know.
And even though this is a Nymex symbol, TT uses CME, for Nymex symbols.
Date Time Of Last Edit: 2025-12-03 18:52:57
[2025-12-03 19:44:35]
User135243 - Posts: 337
The only symbol that the CME-group uses with a different style is the NG (for NG they use 26 for the year, for all other symbols they use 6, curious but a fact)
the current front-month is the Jan-contract: NGF26
Date Time Of Last Edit: 2025-12-03 19:45:33
[2025-12-04 05:18:55]
ok so can this be changed in the backend so the spreadsheet signal order can be routed properly the next time ?
[2025-12-04 05:41:20]
Try again now. This should now be resolved.
[2025-12-04 06:34:43]
yes working now thank you
