Date/Time: Tue, 17 Nov 2026 18:08:54 +0000
not connected
View Count: 401
| [2025-12-01 00:03:52] |
| SurfTrader - Posts: 88 |
Havent used SC in a while. Trying to connect after updating and giving me a connection error Teton CME routing error. I currently just want to use SC for charts, not executing trades, so Im wondering if I need to change any setting as I was trading on SC last time I used it.
| [2025-12-01 00:07:57] |
| Sierra_Chart Engineering - Posts: 25432 |
Do you have an active Teton trading account with your broker? Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. ---- To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-01 00:08:47
| [2025-12-01 01:43:41] |
No I don’t have Teton with my broker. The message log is blank. When I try to connect to data feed i get this message.
Attachment Deleted. Private File |
| [2025-12-01 01:58:29] |
I set data to sc data and I’m connected. Waiting for download historical intraday data. Hopefully that fixed it
| [2025-12-01 02:17:43] |
Ok am connected now but data is delayed. I need to connect to my broker data. Let me see if I can figure it out. I’m using the wrong data feed on my current account. It’s set up for tradovate
Date Time Of Last Edit: 2025-12-01 02:34:00
| [2025-12-01 02:51:54] |
Yes you will be receiving delayed data at this time.
