Date/Time: Wed, 25 Nov 2026 21:24:15 +0000
Spent all day trying to figure this out, why is sierra printing 0's and random numbers?
View Count: 401
| [2025-11-24 21:50:52] |
| User172061 - Posts: 36 |
Hey guys, im trying to get sierra to print imbalances across diagonals and basically nothing else, no 0's and no random -59 and random -23? but it keeps doing that, any help would be appreciated. im not sure if uploading this way si the best or not, and apologies if it isn't i figured this would show the settings AND the chart weird issue at the same time. settings are ask vol bid vol diff diagonal dominant side for lin 16 lin 17 is backgroun on dominnat side 18 is none transparent 19 is based on diag dom ask vol bid vol percentage thanks! |
Private File |
| [2025-11-24 22:56:38] |
The zeros are showing up where neither side is dominant. The uncolored non-zero values are where there is a comparison to zero, and you have the option for "Enable Bid/Ask Ratios with Zeros as Ones" set to "No". Refer to the following: Numbers Bars: Enable Bid/Ask Ratios with Zeros as Ones For both of these, if you do not want to see them, you can set the "Default Text Color" to be the same as the background color. But, this will then cause the other column to not show what you want. You could set a text coloring option in the other column such that you will always get the text colored somehow and set the colors to all be the same. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
