Date/Time: Wed, 25 Nov 2026 21:36:11 +0000
Resetting Cumulative Delta
View Count: 907
[2025-11-17 15:43:47]
User760022 - Posts: 15
I use cumulative delta and would like it reset at 4pm EST, how would I change/input that setting. I've attached a chart of my number bars.
also..is there a way for my Footprint to pull up rather than me having to manually go get it from file when I open sierra chart.
Thank you
Regards
H
imageScreenshot 2025-11-15 at 2.04.30 PM.png / V - Attached On 2025-11-17 15:43:40 UTC - Size: 285.51 KB - 211 views
[2025-11-17 18:51:31]
Refer to this page:
Cumulative Delta Bars - Volume
You need to set the input Reset add Start of Trading Day to Yes.
And you need to set the session times like this (assuming the chart is using US Eastern time):
16:00:00
15:59:59
Refer to:
Chart Session Times
To automatically open Chartbooks, refer to:
General Settings Window: Select Files to Open On Startup (Global Settings >> General Settings >> General >> Startup)
Date Time Of Last Edit: 2025-11-17 18:52:10
[2025-11-27 20:31:58]
Awesome, that answers my question. Going to give it a try tomorrow and see if I did the correct adjustment but I wrote the hours like you mentioned. Can I bother you for another question...
I've always used DOM but have been told to utilize LOB as well so I'm trying to access. Can you give me some guidance in regards to that.
I've also attached some attachments.
Thank you
Regards
Haseeb
imageScreenshot 2025-11-27 at 11.58.24 AM.png / V - Attached On 2025-11-27 20:31:18 UTC - Size: 372.18 KB - 257 views
imageScreenshot 2025-11-27 at 12.04.43 PM.png / V - Attached On 2025-11-27 20:31:30 UTC - Size: 79.82 KB - 247 views
imageScreenshot 2025-11-27 at 11.58.32 AM.png / V - Attached On 2025-11-27 20:31:50 UTC - Size: 140.45 KB - 245 views
[2025-11-30 04:26:29]
What does this mean?:
LOB
Date Time Of Last Edit: 2025-11-30 04:26:35
[2025-11-30 04:55:15]
Limit Order Book
[2025-12-01 04:11:03]
For the limit order book, this is called market depth data, and you need to add the bid size and ask size columns to the Chart DOM. Refer to:
Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns
