Date/Time: Wed, 25 Nov 2026 20:51:54 +0000
Teton data keeps freezing
View Count: 456
| [2025-11-05 16:31:47] |
| User427421 - Posts: 48 |
I'm experiencing some lag and freezing data today on Teton. I've spoken to other users seeing the same issue.
| [2025-11-05 16:45:46] |
| John - SC Support - Posts: 48658 |
There is no particular issue with the Denali data at this time. Please get us your Message Log by following these instructions and we will see if there is anything specific in the log that points to a particular problem: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-05 16:47:55] |
| Sierra_Chart Engineering - Posts: 25483 |
We will do some checking.
| [2025-11-05 17:20:33] |
We did see a delay earlier, of as much as 20 seconds, that temporarily occurred, and the source of the problem could only be related to Internet connectivity. Not with our own systems. What we can say is this only affected some of the server processes and not all, since we use multiple Internet connections. Therefore, only some users would have seen a delay. Not all. Where the Internet connectivity issue was, we do not know. That is very hard to determine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-05 17:21:17
| [2025-11-05 17:21:50] |
it works fine now. Thanks for checking and following up
| [2025-11-05 18:03:08] |
| Flowdity - Posts: 74 |
I have similar lag this week, it happens today as well.
| [2025-11-05 19:01:06] |
In your case since you are in Asia, use the Japan server: (ds45.sierracharts.com): Sierra Chart Server Settings: CME Exchange Data Feed Server Address and Port Override (Global Settings >> Sierra Chart Server Settings >> General >> Special) We checked that today, and it was unaffected by the delay. And in your case since you are in Asia, the reason for the lag at other times would not be related to the issue today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-05 19:01:12
