Date/Time: Wed, 25 Nov 2026 20:51:50 +0000
Assistance Needed: Use Denali Data Feed While Sending Orders to Interactive Brokers
View Count: 465
| [2025-11-04 06:50:59] |
| Juanjo71 - Posts: 4 |
Hello, I have successfully connected Sierra Chart to my Interactive Brokers account, and I have also subscribed to the Denali Data Feed since it provides more reliable and accurate data. The issue I’m facing is that when I use the Interactive Brokers data, the chart quality and accuracy are poor (which I understand is expected). However, when I switch to the Denali data feed, I’m unable to place or route orders through my Interactive Brokers account. I know it is possible to use Denali for charting and still send orders to IB, but I’m not sure how to properly configure this setup. Could you please either configure it directly for me or provide detailed instructions on how to set it up? Thank you very much for your help. Best regards, Juan José Martín López |
| [2025-11-04 14:20:19] |
| John - SC Support - Posts: 48658 |
There is nothing special you need to do in order to get the Denali data and trade with Interactive Brokers. What exactly is occurring when you try to place a trade with Interactive Brokers? What is one symbol for which you have a problem (we need the symbol exactly as you have it entered for the chart). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-04 14:29:08] |
Hello, Thank you for your reply. When I try to place an order through Interactive Brokers while using the Denali data feed, the order does not go through — it seems that Sierra Chart is not routing the trade to IB. For example, I am trying to trade the E-mini S&P 500 futures (symbol: ESZ25-CME). In my chart, the symbol currently used is exactly: ESZ25-CME. Could you please confirm if this is the correct symbol format for using Denali data while routing orders to Interactive Brokers? If not, could you indicate exactly how I should configure the symbol or the “Trade and Current Quote Symbol” settings? If possible, I would appreciate it if you could check my setup remotely to make sure everything is properly configured. Thank you again for your help. Best regards, Juan José Martín López |
| [2025-11-04 14:33:12] |
Hello, I would like to clarify my situation regarding the Denali data feed and Interactive Brokers. When I use Interactive Brokers data, I can place and send orders to IB without any problem. However, when I switch to the Denali data feed, I can only trade in Simulation Mode — Sierra Chart does not allow me to send real orders to Interactive Brokers. For reference, I am trading the E-mini S&P 500 (symbol: ESZ25-CME). Could you please let me know how to configure Sierra Chart so that I can use the Denali data feed for charting while still routing live orders through Interactive Brokers? If possible, I would also appreciate it if you could check my setup remotely to ensure everything is configured correctly. Thank you very much for your help. Best regards, Juan José Martín López |
| [2025-11-04 15:01:58] |
To start with, you need to have your "Current Selected Service" set to "Interactive Brokers". When you make this change and select "OK" on the "Data/Trade Service Settings" window, you will be prompted to update your symbols. Be sure to answer "Yes" to this. If you do not, or if you open another chartbook later, then you can update the symbols by selecting "Edit >> Translate Symbols to Current Service". The general issue you are having is that you do not have the correct symbol for Interactive Brokers. Every service uses a different symbology, so when you are connected to Interactive Brokers, you need to use their symbology. You can always find the correct symbols for the service you are connected to on the "File >> Find Symbol" window. Be sure to select the symbol for a chart through that window in order to ensure that you have it correct. Refer to the following: File Menu: Find Symbol (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
