Date/Time: Wed, 25 Nov 2026 20:52:09 +0000
searching for how to set up a regression channel
View Count: 594
| [2025-11-03 17:43:54] |
| User282886 - Posts: 27 |
Hello, hope you guys are having a great morning. I have been searching for how to set up a regression channel on SC like on Tradingview by chartprime. It is the best one I have seen and I am sure or would like to think it is possible on SC but I can not find it on the studies. Can you help me with this please and maybe send me a link or something on setting this up I would greatly appreciate it. You guys have a great day |
| [2025-11-03 21:19:05] |
| John - SC Support - Posts: 48658 |
We have not used TradingView, so we have no idea what their tool is like. In Sierra Chart, you have a couple of options for the Regression Channel. - First there are "Linear Regression" and "Raff Regression Channel" drawing tools. Refer to the following and the section below it: Chart Drawing Tools: Linear Regression - Second is the "Linear Regression End Channel" Study. Refer to the following: Linear Regression End Channel - There are also the following that may be more for what you are wanting: Linear Regressive Slope Moving Average - Exponential Regression Moving Linear Regression / Moving Average - Linear Regression Moving Linear Regression / Moving Average - Linear Regression For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-03 21:26:22] |
I found those mentioned above but I guess I am missing how to open it from the instructions. I see the explanation but not the how to open or apply it on my charts? Am I missing something here or is it not showing how? Thank you for getting back with me |
| [2025-11-03 21:45:09] |
For a Drawing Tool, you select the tool you want from the Tools menu and then follow the instructions for the particular tool. For a study, refer to the following: Chart Studies: Adding/Modifying Chart Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-03 21:45:16
