Date/Time: Fri, 03 May 2024 20:40:38 +0000
HTTP Error: HTTPSendRequest Failed
View Count: 1834
[2014-10-15 05:02:31] |
User58868 - Posts: 2 |
Dear Support Team, please help me to solve this problem with Sierra Chart login: HTTP Error: HTTPSendRequest Failed Windows Error Code: 2, The system cannot find the file specified Can not make screenshot because can not even login to programm. Thank you |
[2014-10-15 05:06:18] |
For help with this, refer to this section here: http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#LoginProblems Most likely this is due to Internet Explorer being set to work off-line. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-15 05:06:28
