Date/Time: Wed, 25 Nov 2026 20:52:07 +0000
Cross trading settings for 1oz gold with GC on charts, trade rejected illegal price
View Count: 581
[2025-10-30 17:01:07]
dam5h - Posts: 7
I am getting this order rejected with this message:
2025-10-30 16:53:08.578 | Teton CME Routing (Order reject). Info: CME (Rejected). Text: FIX field incorrect 'Illegal Price: '3977.9 contract '1OZZ5' (ticks in 25, CAB of 0)'. SecurityID=42005330. Operator=xxxxx. Text: Parent order. Tag: GLD_2TargetsWithStop.twconfig. Internal Order ID: 1355. Service Order ID: 440136. Symbol: 1OZZ25_FUT_CME. Account: xxxxxx *
I don't know why 3977.9 is an illegal price as this is a valid price on this contract. I can enter orders for 1oz without the cross trading setup on a GC chart but just not when using a GC chart so it seems its a configuration issue.
[2025-10-30 18:43:50]
John - SC Support - Posts: 48658
3977.9 is NOT a valid price for 1OZ. That symbol has a Tick Size of 0.25, therefore the price would need to be either 3977.75 or 3978.00.
If you are using a Gold (GC) chart and using 1OZ as the Trade and Current Quote Symbol, then you would need to change the Tick Size for that chart to be 0.25.
[2025-10-31 01:30:28]
dam5h - Posts: 7
Ah, you are right! I don't know why I assumed it was same as gc with 0.1 ticks.
I updated it on chart settings but it still is not working, is there another setting besides tick size which impacts this?
2025-10-31 01:27:44.747 | Teton CME Routing (Order reject). Info: CME (Rejected). Text: FIX field incorrect 'Illegal Price: '3864.0 contract '1OZZ5' (ticks in 25, CAB of 0)'. SecurityID=42005330. Operator=. Text: Parent order. Tag: GLD_2TargetsWithStop.twconfig. Internal Order ID: 1398. Service Order ID: 441459. Symbol: 1OZZ25_FUT_CME. *
[2025-10-31 13:19:18]
The 1 ounce gold contract uses a different real-time multiplier which you need to set through this particular setting with the configuration you are using:
Chart Settings: Trade and Current Quote Symbol Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
It needs to be set to:
0.01
[2025-10-31 13:27:32]
dam5h - Posts: 7
Okay, now the weirdest thing is happening. I change Real Time Multiplier to 0.01 and Tick Size to 0.25 I hit apply.
1. Chart reloads the tick data, seems okay for a second.
2. Chart then reloads the tick data again and the chart settings automatically revert.
This happens as I am watching it after clicking apply while chart settings are still open, its like it is rejecting the changes I just made.
[2025-10-31 13:52:35]
First make sure you are setting this very specific setting:
And no other.
The Real-Time Price Multiplier for the chart still needs to remain at .1
And disable, the chart linking options:
Chart Settings: Linking
The problem could also be related to:
Unable to Change the Bar Time Period for Charts
Date Time Of Last Edit: 2025-10-31 13:53:37
