Date/Time: Wed, 25 Nov 2026 20:52:11 +0000
change Teton—I have it in AMP—to Denali _CQG no data order routing only
View Count: 704
[2025-10-29 10:09:17]
User716459 - Posts: 204
I need to change Teton—I have it in AMP—to Denali _CQG no data order routing only. Will it work with Sierra 2758? Please reply as soon as possible. Thank you. Best regards.
[2025-10-29 13:55:40]
Yes this is supported:
CQG Trading Platform Service
[2025-10-29 15:16:53]
I requested the inclusion of Denali _CQG no data order routing only.
[2025-10-29 15:38:57]
John - SC Support - Posts: 48658
That is fine, you will still need to setup the connection to CQG as given in the previous link.
But, you do not have any exchanges currently active for the CME Group. Sierra Chart does not have support for data for The CME Group and EUREX with CQG. So if you are wanting to trade either of these exchanges you will need to get that data from us. For the CME Group, you can activate the exchange(s) you want here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
[2025-10-29 16:09:00]
I want to trade GC - Comex, AMP broker.
[2025-10-29 17:04:05]
Then you will need to activate a COMEX exchange at the following link:
And follow the instructions at the following link to connect to CQG:
CQG Trading Platform Service: Setup Instructions
We are curious, if you are trading the CME Group, then why change from Teton to CQG?
[2025-10-29 18:49:22]
How do I pay for data?
I cannot complete the data access setup.
Is CME Non-Professional Top of Book sufficient for me, or do I need Full CME?
Denali CQG requires a smaller deposit.
[2025-10-29 19:08:40]
You have received data from us in the past, so you do not need to redo any agreements. You just need to deposit funds into your account and then activate the exchange(s) for which you want real-time data at the following link:
We can not say what exactly you would need for the data, as we do not know your requirements. The only thing we can state is that you said you needed data for COMEX. The "CME Non-Professional Top-of-Book" is for the CME exchange only, not the Full CME Group. If you need data for COMEX, then you will need to activate an exchange that includes the COMEX, so either one like the "COMEX Non-Professional Top-of-Book" or one of the ones that starts with "Full CME Group (CME, CBOT, COMEX, NYMEX)...".
[2025-10-29 19:34:39]
I asked how to make a payment,
I don't want to make a mistake and pay for the platform, not for the data.
[2025-10-29 20:01:15]
The method to pay for the platform (service package) is the same as for the data. It all goes to a single location for your account (the Services Surplus). What it gets used for is then up to you, and also based on any upcoming fees that will renew automatically.
Use the following page to make a payment:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit#MoveToTop
[2025-10-30 06:22:00]
Good morning.
Is the basic package ($26/month) sufficient for trading on GC - Comex?
[2025-10-30 06:51:05]
Item 12 connection with Cqg CQG Trading Platform Service: Setup Instructions
is not active, select Disconnect.
Please help me.
Thank you.
[2025-10-30 14:03:21]
No. You need to be on one of the "Integrated" packages. You are currently on the "Integrated Standard" package, so right now you are fine. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing: Packages
If you are getting a specific error message, then we need to know what the message states.
[2025-10-30 14:44:33]
1. First time this happened – I am attaching a screenshot. Previously, a static graph and a window with messages appeared.
Private File
[2025-10-30 15:24:18]
That error is stating that the CQG account you are trying to connect to has been disabled. You need to ask your broker about this.
[2025-10-30 15:56:43]
Errors in the attachment
Private File
[2025-10-30 16:45:53]
Refer to what we stated in Post #15.
[2025-10-31 10:56:26]
Good morning.
I have CQG enabled and the message is attached.
Private File
[2025-10-31 13:56:58]
At the time that you posted this, you did not have any exchanges active for the CME Group data from our Denali Exchange Data Feed. Sierra Chart does not have connectivity with CQG for data for The CME Group and EUREX, therefore you have to get that data from our Denali Exchange Data Feed.
We see that you have activated the "Full CME Group (CME, CBOT, COMEX, NYMEX) for Non-Professional Trading Accounts" since then, so you should be fine now.
