Date/Time: Wed, 25 Nov 2026 16:39:24 +0000
Historical Data not downloading
View Count: 522
[2025-10-28 21:27:28]
pavel.lysenka - Posts: 50
Hello
I went away from trading on the 17.10.25 and got back today, and all historical data since then is missing, is there a way i can download it? I tried with edit/download data for all historical charts, but that did nothing. I just have a void on my charts from 17.10- today.
[2025-10-28 21:46:56]
What is the symbol for which you are having an issue?
Also, is this in a sub-instance? If so, then make sure you have the data in the main instance first, and then update the sub-instance and see if that solves the issue.
[2025-10-29 09:59:39]
Es Mini.
I have 4 instances of sierra, and none of them have the historical data over the time I was gone.
[2025-10-29 13:13:31]
Sierra_Chart Engineering - Posts: 25481
Go to one of those Historical Daily charts:
Fully re-download the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Only use this command from the Edit menu at the top of the main window or chart.
Or, in the case of a Continuous Futures Contract chart, follow these instructions:
After about a minute provide a copy of the Message Log following these instructions:
