Date/Time: Wed, 25 Nov 2026 16:39:18 +0000
Request to Enable Numbers Bars for Trial Account
View Count: 529
| [2025-10-26 12:13:44] |
| User591387 - Posts: 1 |
Hello Sierra Chart Support, I am currently using a trial account and would like to request a temporary enablement of the Numbers Bars study (Footprint Chart) for learning and testing purposes. Account Name: PP.SUDA Thank you very much for your help. |
| [2025-10-26 18:06:25] |
| Sierra_Chart Engineering - Posts: 25481 |
Your Sierra Chart account already has access to the Numbers Bars study. You already have full access to all the features. You just are limited on the symbols you can use. Here are the symbols you can use: Sierra Chart Trial Account: Introduction For example you can use the symbol: MESZ25-CME Please try again using the Numbers Bars study: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-26 18:07:06
