Date/Time: Wed, 25 Nov 2026 16:24:55 +0000
Replay with Full Market Depth
View Count: 451
| [2025-10-15 18:10:55] |
| kero kero - Posts: 8 |
Hi, I hope you are doing well. I'm currently having issues replaying the dom. I can explain to you the situation. This is the DOM i am refering to: https://postimg.cc/D8LHbdD8 Whenever i replay it it goes to the date of 16th of September but i can't replay earlier this year, do i have to purchase any datasets or am i wrong on something? I also did a video with OBS recorder so you can see when i replay - the input date - and the result: https://streamable.com/dm44ox Regards |
| [2025-10-15 18:13:21] |
Replays can only be done on the data that is already loaded in the chart. So if you want to go back to before September 16, then you need to have that data already loaded in the chart. Refer to steps 3 and 4 at the following link: Replaying Charts: Basic Chart Replay Instructions And keep in mind that if this is a Futures chart, then you may need to use the "Continuous Futures Contract" option in order to view older data. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
