Date/Time: Thu, 02 May 2024 08:09:22 +0000
Auto trading enabled
View Count: 2767
[2013-05-13 13:44:31] |
GPST10 - Posts: 139 |
Why there is auto trading enabled on my charts under trade. Worrying because there was several times new orders appeared without my knowledge. Any ideas? |
[2013-05-13 15:32:04] |
Do you use an automated trading system? Whether the global option to enable automated trading is enabled or not, there will not be an automated order submitted unless you are deliberately using an automated trading system that you have very clear knowledge of and have specifically enabled. An automated trading system itself has to be enabled independently of the global option. Please contact your broker about this. If you are seeing orders that are not yours, you must contact your Broker about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-13 15:55:07] |
It is very important that we see the Trade Activity Log for these orders you are making reference to so we can see the origin of them. That will make it quite clear where they originated from. Please follow these instructions and provide us that information: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#TradeActivityLogToSupport Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-13 16:08:46] |
Unfortunately I'm not at the desk right now. I never did anything regarding Automatic Trading ever. The orders wasn't going out to Transact but appeared three times only on charts so it should be locally only. The one other thing I noticed in a fast market when trading from charts was after I enter chart order and cancel right away it gave error and I couldn't remove it but back checking with trading software they where not there. So just little bit of annoyance with all that kind of activity. I will send you log next time I'm there if its happens again. Also I don't know if that what I saw was anything to do with Automatic trading, I'm just naturally went to TRADE settings and find it Enabled, I wish I would know how to disable it. |
[2013-05-13 16:10:32] |
We do not think this is related to automated trading. That would be very unlikely. There are too many safeguards in place which would prevent that. You can contact TransAct support about this and ask for Bob. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-13 16:13:07] |
I really don't think so because the orders appeared on chart only.
[2013-05-13 16:20:19] |
OK, unless we see the Trade Activity Log as requested we cannot determine what the problem is. The answer is right there in the log. You should also definitely contact TransAct support about this and ask for Bob. They did request that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-13 16:21:42
[2013-05-13 16:37:26] |
Ok
[2013-05-13 23:25:21] |
What would be recommended option to send Trade Activity Log safely over?
[2013-05-13 23:35:46] |
It is easiest if you just post the relevant lines here. There's no harm in doing so. These orders are not yours, so there should be no problem with this. Just simply post the order lines from the Trade >> Trade Activity Log >>Trade Activity tab which shows orders that are not ones you submitted. Once again here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#TradeActivityLogToSupport Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-13 23:50:41] |
Its better if I encounter it again, if so Ill know where to look because I have a lot of activity and its hard to pinpoint especially when few times there with the other problem when hard to cancel as well.
[2013-05-13 23:59:37] |
Ok just happened I removed my acc number at each line only. Orders still there - should I cancel? ActivityType DateTime Symbol OrderActionSource InternalOrderID ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity AccountInfo OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID Order 2013-05-13 19:43:29.000 6EM3 TransAct order update 3911 22598640 Limit 1 Buy 1.2982 Open Order 2013-05-13 19:43:29.001 6EM3 TransAct order update 3912 22598641 Limit 1 Buy 1.2981 Open Order 2013-05-13 19:43:29.002 6EM3 TransAct order update 3913 22598642 Limit 1 Buy 1.2980 Open Order 2013-05-13 19:43:29.003 6EM3 TransAct order update 3914 22598643 Limit 1 Buy 1.2981 Open Order 2013-05-13 19:43:29.004 6EM3 TransAct order update 3915 22598644 Limit 1 Buy 1.2982 Open Order 2013-05-13 19:43:29.005 6EM3 TransAct order update 3916 22598645 Limit 1 Buy 1.2981 Open Order 2013-05-13 19:43:29.006 6EM3 TransAct order update 3917 22598646 Limit 1 Buy 1.2982 Open |
[2013-05-14 00:01:21] |
I never touched that screen!
[2013-05-14 00:05:30] |
I just cancelled and they never appeared on TA software - really strange and scary!
Date Time Of Last Edit: 2013-05-14 00:05:57
[2013-05-14 00:09:23] |
Trade Service Log: There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598640 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598642 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598644 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 0 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598645 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598643 | 2013-05-13 20:03:02 There was an error with the order cancellation: TransAct cancel error: Failed to Cancel Order. Service order ID: 22598641 | 2013-05-13 20:03:02 |
[2013-05-14 01:03:53] |
This is the Trade Activity Log from this morning in case. ActivityType DateTime Symbol OrderActionSource InternalOrderID ServiceOrderID OrderType Quantity BuySell Price Price2 OrderStatus FillPrice FilledQuantity AccountInfo OpenClose ParentInternalOrderID PositionQuantity FillExecutionServiceID Order 2013-05-13 09:38:08.000 YMM3 TransAct order update 3776 22593746 Stop 1 Buy 15061 Open xxx Order 2013-05-13 09:38:08.001 YMM3 TransAct order update 3777 22593748 Stop 1 Buy 15058 Open xxx Order 2013-05-13 09:38:08.002 YMM3 TransAct order update 3778 22593764 Stop 1 Buy 15057 Open xxx Order 2013-05-13 09:38:08.003 YMM3 TransAct order update 3779 22593765 Stop 1 Buy 15060 Open xxx Order 2013-05-13 09:38:08.004 YMM3 TransAct order update 3780 22593766 Stop 1 Buy 15061 Open xxx Order 2013-05-13 09:38:08.005 YMM3 TransAct order update 3781 22593768 Stop 1 Buy 15062 Open xxx Order 2013-05-13 09:38:08.006 YMM3 TransAct order update 3782 22593769 Stop 1 Buy 15047 Open xxx Order 2013-05-13 09:38:08.007 YMM3 TransAct order update 3783 22593770 Stop 1 Buy 15049 Open xxx Order 2013-05-13 09:38:08.008 NQM3 TransAct order update 3784 22593784 Limit 1 Sell 2972.00 Open xxx -3 Order 2013-05-13 09:38:08.009 YMM3 TransAct order update 3785 22593801 Stop 1 Buy 15050 Open xxx Order 2013-05-13 09:38:08.010 YMM3 TransAct order update 3786 22593802 Stop 1 Buy 15052 Open xxx Order 2013-05-13 09:38:08.011 YMM3 TransAct order update 3787 22593803 Stop 1 Buy 15057 Open xxx Order 2013-05-13 09:38:08.012 YMM3 TransAct order update 3788 22593804 Stop 1 Buy 15063 Open xxx Order 2013-05-13 09:38:08.013 YMM3 TransAct order update 3789 22593806 Stop 1 Buy 15050 Open xxx Order 2013-05-13 09:38:08.014 YMM3 TransAct order update 3790 22593807 Stop 1 Buy 15049 Open xxx Order 2013-05-13 09:38:08.015 YMM3 TransAct order update 3791 22593808 Stop 1 Buy 15047 Open xxx Order 2013-05-13 09:38:08.016 YMM3 TransAct order update 3792 22593810 Stop 1 Buy 15052 Open xxx Order 2013-05-13 09:38:08.017 NQM3 TransAct order update 3793 22593827 Stop 1 Buy 2972.50 Open xxx -3 Order 2013-05-13 09:38:08.018 NQM3 TransAct order update 3794 22593828 Stop 1 Buy 2972.75 Open xxx -3 Order 2013-05-13 09:38:08.019 NQM3 TransAct order update 3795 22593831 Limit 1 Buy 2969.25 Open xxx -3 Order 2013-05-13 09:38:36.000 YMM3 Canceling all orders for symbol YMM3 3776 22593746 Stop 1 Buy 15061 Pending Cancel xxx Order 2013-05-13 09:38:36.001 YMM3 Canceling all orders for symbol YMM3 3777 22593748 Stop 1 Buy 15058 Pending Cancel xxx Order 2013-05-13 09:38:36.002 YMM3 Canceling all orders for symbol YMM3 3778 22593764 Stop 1 Buy 15057 Pending Cancel xxx Order 2013-05-13 09:38:36.003 YMM3 Canceling all orders for symbol YMM3 3779 22593765 Stop 1 Buy 15060 Pending Cancel xxx Order 2013-05-13 09:38:36.004 YMM3 Canceling all orders for symbol YMM3 3780 22593766 Stop 1 Buy 15061 Pending Cancel xxx Order 2013-05-13 09:38:36.005 YMM3 Canceling all orders for symbol YMM3 3781 22593768 Stop 1 Buy 15062 Pending Cancel xxx Order 2013-05-13 09:38:36.006 YMM3 Canceling all orders for symbol YMM3 3782 22593769 Stop 1 Buy 15047 Pending Cancel xxx Order 2013-05-13 09:38:36.007 YMM3 Canceling all orders for symbol YMM3 3783 22593770 Stop 1 Buy 15049 Pending Cancel xxx Order 2013-05-13 09:38:36.008 YMM3 Canceling all orders for symbol YMM3 3785 22593801 Stop 1 Buy 15050 Pending Cancel xxx Order 2013-05-13 09:38:36.009 YMM3 Canceling all orders for symbol YMM3 3786 22593802 Stop 1 Buy 15052 Pending Cancel xxx Order 2013-05-13 09:38:36.010 YMM3 Canceling all orders for symbol YMM3 3787 22593803 Stop 1 Buy 15057 Pending Cancel xxx Order 2013-05-13 09:38:36.011 YMM3 Canceling all orders for symbol YMM3 3788 22593804 Stop 1 Buy 15063 Pending Cancel xxx Order 2013-05-13 09:38:36.012 YMM3 Canceling all orders for symbol YMM3 3789 22593806 Stop 1 Buy 15050 Pending Cancel xxx Order 2013-05-13 09:38:36.013 YMM3 Canceling all orders for symbol YMM3 3790 22593807 Stop 1 Buy 15049 Pending Cancel xxx Order 2013-05-13 09:38:36.014 YMM3 Canceling all orders for symbol YMM3 3791 22593808 Stop 1 Buy 15047 Pending Cancel xxx Order 2013-05-13 09:38:36.015 YMM3 Canceling all orders for symbol YMM3 3792 22593810 Stop 1 Buy 15052 Pending Cancel xxx Order 2013-05-13 09:38:37.000 YMM3 TransAct cancel error: Failed to Cancel Order 3778 22593764 Stop 1 Buy 15057 Open xxx Order 2013-05-13 09:38:37.001 YMM3 TransAct cancel error: Failed to Cancel Order 3776 22593746 Stop 1 Buy 15061 Open xxx Order 2013-05-13 09:38:37.002 YMM3 TransAct cancel error: Failed to Cancel Order 3777 22593748 Stop 1 Buy 15058 Open xxx Order 2013-05-13 09:38:37.003 YMM3 TransAct cancel error: Failed to Cancel Order 3779 22593765 Stop 1 Buy 15060 Open xxx Order 2013-05-13 09:38:37.004 YMM3 TransAct cancel error: Failed to Cancel Order 3781 22593768 Stop 1 Buy 15062 Open xxx Order 2013-05-13 09:38:37.005 YMM3 TransAct cancel error: Failed to Cancel Order 3780 22593766 Stop 1 Buy 15061 Open xxx Order 2013-05-13 09:38:37.006 YMM3 TransAct cancel error: Failed to Cancel Order 3783 22593770 Stop 1 Buy 15049 Open xxx Order 2013-05-13 09:38:37.007 YMM3 TransAct cancel error: Failed to Cancel Order 3786 22593802 Stop 1 Buy 15052 Open xxx Order 2013-05-13 09:38:37.008 YMM3 TransAct cancel error: Failed to Cancel Order 3782 22593769 Stop 1 Buy 15047 Open xxx Order 2013-05-13 09:38:37.009 YMM3 TransAct cancel error: Failed to Cancel Order 3787 22593803 Stop 1 Buy 15057 Open xxx Order 2013-05-13 09:38:37.010 YMM3 TransAct cancel error: Failed to Cancel Order 3790 22593807 Stop 1 Buy 15049 Open xxx Order 2013-05-13 09:38:37.011 YMM3 TransAct cancel error: Failed to Cancel Order 3788 22593804 Stop 1 Buy 15063 Open xxx Order 2013-05-13 09:38:37.012 YMM3 TransAct cancel error: Failed to Cancel Order 3789 22593806 Stop 1 Buy 15050 Open xxx Order 2013-05-13 09:38:37.013 YMM3 TransAct cancel error: Failed to Cancel Order 3785 22593801 Stop 1 Buy 15050 Open xxx |
[2013-05-14 01:21:05] |
We need to report this to TransAct. Thank you for the info.
[2013-05-14 01:21:59] |
Ok
[2013-05-14 22:28:49] |
The source of this problem has now been discovered. Please update to version 975. Help >> Download Current Version.
