Date/Time: Sat, 18 May 2024 11:28:15 +0000
Study Overlay Problems
View Count: 996
[2014-10-13 10:46:50] |
Glyn - Posts: 20 |
When the Study/Price Overlay is transferred from a Range Chart to a 1 minute chart, only a limited and variable number of transferred values are displayed on the 1 minute chart. This is resolved by a forced recalculation which allows the most recent levels to be displayed again. However, after a few more periods the transfer lines will again disappear. For example, a study of the range bar high (using a simple moving average 1) displaced 2 periods and then transferred to a 1 minute chart, shows the problem. Also, no new overlay level is formed when a new range bar commences. Interestingly, a non-displaced overlay continues to be drawn correctly throughout. SC1200. |
[2014-10-13 21:03:21] |
We will be checking on this today.
[2014-11-04 03:53:23] |
We are finally getting to this now.
[2014-11-04 08:42:45] |
Glyn - Posts: 20 |
I think the answer may be to use the setting "Use Earliest Value From Corresponding Timeframe In Source Chart" rather than "Latest Value...". Will this be a universal remedy for all displaced studies? |
[2014-11-04 08:52:04] |
We have discovered and corrected the problem and it will be out in the next release.
