Date/Time: Tue, 17 Nov 2026 18:09:09 +0000
Why I am not getting Realtime QQQ data?
View Count: 646
[2025-09-30 17:01:34]
User337568 - Posts: 65
I thought I signed everything necessary.
[2025-09-30 18:05:49]
John - SC Support - Posts: 48555
You are setup to get the "U.S. Equities Consolidated Tape" data along with the "NASDAQ TotalView", so depending on what symbol you use exactly, will determine whether the data is from one or the other or both (i.e. QQQ, QQQ-NQTV, or QQQ_MBO).
What is the exact symbol you are using (we need the symbol exactly as it is entered on "Chart >> Chart Settings >> Symbol >> Symbol)?
Do you have any data in the chart?
[2025-09-30 18:10:33]
QQQ is Live - thank you.
Trying to get SPX_CGI and VIX_CGI
[2025-09-30 18:33:39]
Those symbols are part of our "CBOE Indices" exchange. You are not setup to get data for that exchange, therefore you will not get any data at all for these symbols (we do not have delayed streaming data for that exchange). To get this data, you would need to setup the CBOE Indices exchange by following these instructions:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
