Date/Time: Wed, 25 Nov 2026 16:03:22 +0000
different rithmic account on different PCs.
View Count: 674
| [2025-09-23 07:48:59] |
| User981449 - Posts: 52 |
Hi, I’d like to connect two different Rithmic accounts on two separate PCs using Sierra Chart. The issue is that when both are online, one of them doesn’t receive data because I only have Denali activated for one PC. Is it possible to use Denali on just one PC and use Rithmic as the data feed on the second PC, or do I need to activate a second Denali license? |
| [2025-09-23 15:55:29] |
You can do this either way. 1. To connect to Denali on one PC and Rithmic on the other: - On the PC where you want to use the Rithmic data, set the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to "No". - Select OK to close that window. - Select "File >> Reconnect" Refer to the following: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) 2. To use the Denali Exchange Data Feed to two computers simultaneously: - Follow the instructions here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
