Date/Time: Thu, 19 Nov 2026 13:27:23 +0000
What do I need to have number bar(foot print) for stocks trading and option trading
View Count: 1193
| [2025-09-11 22:58:46] |
| User993746 - Posts: 11 |
I want to trade both options and stocks. I am not a professional. For stocks I need foot print and for options I need option chain - both real time data. I understand I need package 11 - cost is 46 usd but what about exchange package? What exchange package I need to choose for my use case? and what is the cost ? Do I need Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional Trading accounts for 39 USD? Or Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts for 6 USD? OR NASDAQ TotalView US stock data Also what is the cost per month for Denali exchange fees and what is separate cost for exchange fees? |
| [2025-09-12 14:46:20] |
| John - SC Support - Posts: 48583 |
To start with, we do not have Options for the U.S. Equities. If you need this data, then the only broker we connect with that has this is Interactive Brokers. Since you want the footprint (Numbers Bars), you do need to be on one of the "Advanced" packages, and in order to get data and connect to trading services, you need to be one of the "Integrated" packages. Therefore the minimum package you need is the "Integrated Advanced" package (Package 11). The cost for this is $46.00 per month. The CME Group is futures data, therefore we assume you do not want that data. We have two different exchange options for U.S. Equities, as well as the option to combine these. Refer to the following: US Stock/Equities Consolidated Tape Data Feed Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView The "Denali exchange fees" and the "exchange fees" are the same thing. There is the package fee and the exchange fees. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-12 17:22:59] |
Ok for options chain I must connect with interactive brokers and get data from them because you dont support or provide data for that. For stocks to confirm I have two options 1. Nasdaq totalview data fees for 17$ or 2. Us equities consolitated tape with nasdaq total view which is 17+10 = 27 usd? So total 46 plus 17 or 46 + 27 usd correct? |
| [2025-09-12 17:26:34] |
Correct.
| [2025-10-26 04:46:34] |
Ok just wondering since I am getting data for options from interactive - why can't I get data from interactive for stocks as well so I can avoid paying you for exchange data feed - is it possible? Apart from interactive - is there any other broker I can get data for both stocks and options ? for example schwab, alpaca,tradestation or fidelity? |
| [2025-10-27 15:06:39] |
You can get the Stock data from Interactive Brokers as well. That is up to you. The only other potential source for this data is DTN IQ Feed. We know they have the Stock data, but we do not know if they have the Options data. You can check with them, if you want. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-27 17:01:16] |
I am specifically interested in footprint chart so I need level 2 data so is there any advantage of buying data from you (Denali) compared to interactive data? also do you know to replace denali nasdaq totalview do you know what exactly I need from interactive? |
| [2025-10-27 19:09:24] |
We do not know enough about Interactive Brokers Level 2 data to be able to answer these questions. We have set this as a "User Discussion" as other users may be able to answer your questions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 02:01:07] |
I have had trial before but I could make any use of it..I was not ready. So can you extend the trial for another 21 days thanks. I wan to make sure it works for me ...particularly with data. Thanks.
| [2025-10-28 15:20:10] |
Since it has been more than 6 months since you last used Sierra Chart, we have reset the trial for your account. So you have the full 21 days of trial time available. Note that during a trial, you have limited data access. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-28 22:52:51] |
Thanks..I understand about data limitation so I was going to buy denail data from you ...nasdaq total view but I learned that I should wait until the 1st of the month otherwise I will be billed twice. I should have requested you to reset it effective 1st of nov but now its water over the bridge. |
| [2025-10-31 15:41:33] |
Hello I have hard time setting number bar chart as well as delta / cumulative volume delta in number format at the bottom of the chart is there any template I can download from sierra chart or some freely available source on internet? |
| [2026-08-03 08:05:38] |
| Sierra_Chart Engineering - Posts: 25441 |
For some reason your question had gotten overlooked. What you want to use is called Numbers Bars Calculated Values: Numbers Bars: Displaying Numeric Information Below Numbers Bars There is no template. You just simply add the study to the chart and configure it. Instructions are provided in the link above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-03 08:05:51
