Date/Time: Wed, 25 Nov 2026 07:56:03 +0000
Volume Drawing Tool
View Count: 528
| [2025-09-08 19:56:51] |
| User374714 - Posts: 6 |
Volume Drawing Tool Unfortunately, it's no longer possible to delete the drawing tool. I can't select it anymore, but deleting the volume tool, which is available under Drawing Tools, doesn't work either. Thanks. See you later. |
| [2025-09-08 21:39:51] |
| John - SC Support - Posts: 48648 |
In terms of selecting the Drawn Volume Profile, refer to the settings in the following section and make sure they are set as you want them: Chart Drawing Tools: Volume Profiles (Global Settings >> Tool Settings >> General) We are not sure what you are referencing in terms of "but deleting the volume tool, which is available under Drawing Tools, doesn't work either." What items are you specifically referring to in this case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-09 06:22:24] |
Hi! Hab es heraus gefunden, und zwar war noch Volumen Indikator aktive aber nicht sichtbar. Als ich den entfernt habe wahr auch das Zeichen toll weg. |
