Date/Time: Tue, 03 Nov 2026 17:43:27 +0000
micro 10yr yield delayed data
View Count: 448
| [2025-09-04 15:16:32] |
| User250571 - Posts: 13 |
I can not get live data for the micro 10-year yield futures. I am currently using the correct symbol 10YU25_FUT_CME. I also went through all the trouble shooting steps suggested that I could find. I believe I have the correct package and the correct feed to get live data. I can not get the feed to go live. Please let me know what I can try. Thanks for your help in advance. |
| [2025-09-04 15:55:12] |
| John - SC Support - Posts: 48408 |
The Treasury Futures are traded on the CBOT exchange of the CME Group. You have the "CME with Market Depth for Non-Professional Trading Accounts" active right now. This is just the CME exchange, not the Full CME Group, which is composed of 4 exchanges (CME, CBOT, COMEX, and NYMEX). Therefore, you need to activate an option to get the data for CBOT in order to get the real-time data for the treasury futures. Refer to the following: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
