Date/Time: Wed, 25 Nov 2026 07:55:51 +0000
Numbers Bar Calculated values Delta % Per Candle
View Count: 1328
| [2025-09-02 23:18:32] |
| User167095 - Posts: 1 |
Hey team Im quite new to sierra :) so far doing great . but i cant figure out how to set in Numbers Bar Calculated values the delta % of each candle/bar so lets say a canlde is 1K Volume and positive delta of 200 its 20% delta . cant find the correct column for it in Numbers Bar Calculated values Also i have study subgraph above bars as text set to Ask Volume Bid Volume difference SG1 it shows the delta okay but with .00 after , how do i remove the zeros? cheers |
| [2025-09-03 15:00:56] |
| John - SC Support - Posts: 48648 |
The Numbers Bars Calculated Values subgraph you want is the "Ask Volume Bid Volume Difference Percent". You will find the definition for this (and all the other subgraphs) at the following link: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions To change how the "Study Subgraph Above Below Bar As Text" displays, you need to change the "Value Format" for that study. Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
