Date/Time: Tue, 03 Nov 2026 17:43:11 +0000
Inconsistent backtest speed
View Count: 1443
[2025-08-29 19:01:54]
User827002 - Posts: 47
I have multiple instances of Sierra charts downloaded so that I can have multiple backtests running at the same time. On one instance, if I have it set to replay single chart it replays smoothly. On another instance that has all the same settings (as far as I'm aware) it is incredibly choppy. Both replay smoothly when I have them set to replay all charts in chartbook, but I only have one chart in the chartbook and I'd like to replay the single chart so that it can skip the empty periods. I've experimented with changing the chart update in milliseconds from 250 to 10 and changing the replay speed but that doesn't really change anything. Its set to accurate trading system back test mode. Do you know what the problem might be or at least how I can troubleshoot it?
[2025-08-29 20:45:21]
Sierra_Chart Engineering - Posts: 25362
Check Chart >> Chart Settings >> Display >> Replay Update Interval In Milliseconds
And also check to confirm there is tick by tick data:
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
[2025-08-31 17:50:11]
The replay update interval in milliseconds is set to 0 on the smooth and the choppy instances. Changing it didn't make a difference, and every instance is set to a tick by tick data configuration. I've also tried copying the global settings files from one instance to another and that didn't make any difference either. Do you have any other ideas as to what the problem might be?
[2025-09-02 18:16:47]
Set Chart >> Chart Settings >> Display >> Replay Update Interval In Milliseconds to 100.
Make sure you have tick by tick data (essential):
On the Replay Window interface:
Set the Charts to Replay to a single chart:
Replaying Charts: Charts to Replay
Set the Replay Mode to Standard Replay:
Replaying Charts: Replay Mode
You should not have any issue with that single chart.
Date Time Of Last Edit: 2025-09-02 18:17:25
[2025-09-24 12:27:29]
Lowry BigEarth - Posts: 51
1. How fast your playback / replay engine works on numbers bars? ...for backtesting an algo strategy / custom study with tick data on numbers bars? How many ticks or seconds of historical data per realtime second does the engine run? Like How long it takes to run full day ETH (extended trading hours) of tickdata of ES or NQ with numbers bars?
2. What is Included in the Free Trial?
How to get Full contracts - ES and NQ - into free trial for study development and backtesting/replay/playback? Did not find these here> Sierra Chart Trial Account
2.1. OR can you make/ offer a special package for algo strategy development and backtesting / replay / playback with cheapest historical data and possibly cheapest delayed tick data feed. Development might take longer than 21 days... Like 5 USD per month or smth...
3. For numbers bars tick data seems I need service pack 5 right? > Description of Service Packages and Pricing: Packages
Thank you,
Lauri
[2025-09-24 15:30:11]
1. We do not know the answer to this. It depends upon, the amount of data that there is which can vary widely based upon the symbol and date, and the speed of the computer. You can do your own testing. We will activate your account temporarily for this.
2. You have to pay for an account.
However, we have now activated your account for a week at service package 11. So you can do testing for all symbols.
2.1. There is no special pricing available but Sierra Chart is already inexpensive. For the package that you would need for what you want to do, this is $23.40 a month if you pay for 12 months in advance :
Description of Service Packages and Pricing: Multiple Month Purchase Discount
3. Yes this is correct.
Date Time Of Last Edit: 2025-09-24 15:32:28
