Date/Time: Wed, 25 Nov 2026 07:55:46 +0000
Setting imbalances on numbers bars
View Count: 1455
[2025-08-28 18:07:38]
Valtteri - Posts: 1
Hi, I can't figure out how to set up imbalances properly on numbers bars.
Here is how it's looking now:
[image: image.png]
There are way too many, I would like to have the footprint setup the same
way as it is right now but I only want to change the imbalance rate to
lower.
This is how I had it on ATAS:
[image: image.png]
The imbalance rate was set up to 200. How can I set up the imbalances the
same way?
imagetmp_1756367712_image.png / V - Attached On 2025-08-28 18:07:31 UTC - Size: 151.49 KB - 221 views
imagetmp_1756367711_image.png / V - Attached On 2025-08-28 18:07:34 UTC - Size: 19.68 KB - 300 views
[2025-08-28 18:08:12]
Refer to the following:
Numbers Bars: Display Ask/Bid Imbalance
