Date/Time: Wed, 25 Nov 2026 16:03:09 +0000
Copying chartbook with spreadsheet
View Count: 473
[2025-08-26 14:45:09]
User361939 - Posts: 171
please help me understand.
I have chartbook with gold and couple of spreadsheet inside.
I want to use those spreadsheets as well on crude.
I create new chartbook, copy all "gold" charts into new charbook with also spreadsheets.(copy all charts to chartbook option)
I changed instrument to CL in new chartbook, so every chart have CL.
Do i need additionally do something with spreadsheets? I notice name for spreadsheets, after coppying and changing instrument is the same as in "GOLD chartbook", indicator for spreadsheet also pointing into same "sheet" inside spreadsheet as on gold charts. Is there a conflict? Should i do smth different way?
Regards
Date Time Of Last Edit: 2025-08-26 15:44:29
[2025-08-26 16:33:16]
There are a lot of complications related to this, but there are ways to mitigate it, but it depends a lot on exactly how you have the Spreadsheet Study setup and the particular chart numbers that were copied from/to.
But, in the end, the best thing to do is to have a different spreadsheet file for each chartbook. What you will want to do is to change the spreadsheet filename that is used in the copied (CL) charts. Open the Spreadsheet Study for each of those charts and change the filename in the following location:
Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name
Once you have the new filenames setup, then you will be fine.
Note that if you are using different spreadsheet files for each chart for Gold, then you will want to do the same thing for Crude. If you were using a single spreadsheet file for all the Gold charts, then you should be able to use just a single spreadsheet file for all the Crude charts.
