Date/Time: Tue, 24 Nov 2026 18:17:06 +0000
Delayed data on second instance but not the first
View Count: 472
[2025-08-20 18:16:47]
User968091 - Posts: 49
Trying to connect to Dorman/Teton and data is delayed with broker.
[2025-08-20 18:22:48]
John - SC Support - Posts: 48643
If you are connecting from two different computers, then the issue is that the exchanges do not allow for the data to go to two different computers at the same time without paying a second set of exchange fees. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
If these two instances are on the same computer, then you should not have an issue with one getting real-time data and the other getting the delayed streaming data (or not data). In this case, we would need to see the Message Log from the instance that has the delayed streaming data (or no data) by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
