Date/Time: Wed, 25 Nov 2026 16:14:58 +0000
Modifying my Sierra chart on free trial.
View Count: 709
| [2025-08-01 14:49:03] |
| Harrison Ssentongo - Posts: 4 |
Hey community, i have the following concerns. Please get back to me. 1. does the free trial have all packages like the package 5? 2. When a subscriber or sierra chart user (who subscribed to package 5) shares their chart book to another user (who uses free trial) does the chart of the free trial subscriber look the same as the one who paid? Otherwise are there any limitations because i find my charts blank yet others' charts are working . 3. lastly, can a chat on free trial be modified till this (the image is in the file attached)? i mean can i add the following tools? for my trading? |
| Attachment Deleted. |
| [2025-08-01 17:05:50] |
1. The Free Trial has all the capabilities of the system, but you are limited on the data. Refer to the following: Sierra Chart Trial Account 2. It depends. The most likely issue is that the charts that are blank are for a symbol for which you do not have access on the trial. Change those charts to a symbol for which you do have access. Refer to the following: Changing the Symbol of a Chart Since this will be a different symbol, the data will be different, but the chart should be similar in terms of layout and what is displayed. 3. We are not understanding this question. Are you referring to the Chat program or "chart"? If you are asking about the chart, then we think we answered the question in the above. If it is about Chat, then we need more information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-03 00:34:27] |
Thank you so much for this information. It’s quite delightful but less of resolution to my concern. I did add assets to my chart already. My concern is how I add tools such as the delta (change, percentage, max, min among others.) and modifying them since you stated that the free package is not limited. I think the chart I sent also had bars. So please, get back to me with those answers. Let me reshare the screenshot again.
Private File Attachment Deleted. Private File |
| [2025-08-04 15:35:58] |
We need more specific information on what you are looking for. The image shows a chart with the Numbers Bars study on it. Are you wondering about Delta, Max, Min for the Numbers Bars? Or is it something else? The documentation for the Numbers Bars is here: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
