Date/Time: Wed, 25 Nov 2026 16:25:12 +0000
Setting Alers and Volume ratio by time of a day
View Count: 475
| [2025-07-29 10:09:53] |
| User274708 - Posts: 15 |
Hello, Is there a way to shorter Alert Text or Source name tab in Alert Manager to decrease significantly it length to 3/4 or 5 letters/signs? I tried ''Short Name'' inside the study but that does not fix what I want - Alert still will generate the whole formula of text. Is there a way to clear the log alerts every 60 seconds automatically ? Date Time Of Last Edit: 2025-07-29 13:36:20
| [2025-07-29 13:57:34] |
Refer to the following for the one option available related to this: General Settings Window: Use User Defined Name Only in Alert Message (Global Settings >> General Settings >> Alerts >> User Defined Name) You mention a study, so if you are doing this from a custom study, then you need to look at what function you are using to add the alert and the options available for it. Is there a way to clear the log alerts every 60 seconds automatically ?
There is not a way to do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-29 15:56:58] |
Thank you that helped. However I set alerts for 3 instances that works perfectly, but the 4th instance doesnt produce the demanded sounds or text alert, is there a limit to it ? Settings are all the same for all instances |
| [2025-07-29 19:22:35] |
There are no limitations on the number of systems that can create alerts. Refer to the following items that might help you: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play General Settings Window: Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound (Global Settings >> General Settings >> Alerts >> Additional Settings) Also, if your instances are sub-instances, then you might want to enable the "Remote Alerts" so that all the alerts are actually routed to a single instance which can then have better control over the playing of the sounds. Refer to the following: General Settings Window: Remote Alerts (Global Settings >> General Settings >> Alerts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-30 10:58:22] |
Thank you John that helped. As you said there is no way to clear alerts log autmatically - is that something that maybe you could easliy adapt for one of the upcoming updates ? Would it be possible ? It would be very helpfull |
| [2025-07-30 13:58:31] |
You can create a custom study to automatically clear the alert sound queue. Refer to the following: ACSIL Interface Members - Functions: sc.ClearAlertSoundQueue() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
