Date/Time: Tue, 17 Nov 2026 18:08:52 +0000
Futures options chart symbol
View Count: 581
| [2025-07-26 18:52:19] |
| User343060 - Posts: 8 |
Hi, Is it possible to chart futures options ? Is it possible with "base advanced" package ? What would be the symbol for example for the options : Corn july contract 300 Put Thanks, Regards |
| [2025-07-27 17:59:14] |
| Sierra_Chart Engineering - Posts: 25432 |
Yes you can get this data. With the Delayed Exchange Data Feed: Delayed Exchange Data Feed To get the list of options, refer to: Denali Exchange Data Feed: Denali Futures Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-27 17:59:25
