Date/Time: Wed, 25 Nov 2026 16:25:15 +0000
Info Tick chart study price overlay on dom
View Count: 681
[2025-07-21 18:41:21]
User172301 - Posts: 2
Good morning,
can you tell me how to configure the tick by tick chart on dom because it is shown too compressed if the price ladder is wide on the dom, in this case the price movements of the tick chart are not displayed well and it almost looks like a flat line.
I really need an help please.
Best Regards
[2025-07-21 18:42:48]
What exactly do you mean by "configure tick by tick chart on DOM"? If you are referring to a "Trading DOM" then you can not get the bars to show properly on this DOM. The Trading DOM does not have the same concept of bars as a chart.
Please give us more information, and an image, so we can understand what you are trying to do and the issue you are having.
[2025-07-24 16:29:38]
I am referring to trading DOM yes, attached two images.
As you can see in one image the horizontal axis is more compressed than in the other.
I would like to visualize the chart attached to the DOM in the same way if possible.
Thank you
Private File
Private File
[2025-07-24 17:34:41]
Sierra_Chart Engineering - Posts: 25481
Refer to:
Chart Scale and Scale Adjusting: Interactive Scaling
And refer to:
The Chart DOM Scale
