Date/Time: Wed, 25 Nov 2026 22:25:59 +0000
Multiple trading accounts
View Count: 785
| [2025-07-15 13:47:26] |
| Jimmyy - Posts: 358 |
I have multiple trading account with the same broker and same clearing firm. Is it possible to display both the accounts one below other in trade account monitor thanks |
| [2025-07-15 16:51:53] |
It depends on how the accounts are setup. If these accounts are all accessible under a single login, then all of the accounts will show up in a single installation of Sierra Chart connected to that broker. In this case, the accounts will all show in the "Trade Account Monitor". If, on the other hand, the accounts are separate logins, then it is best to have separate installations of Sierra Chart to access each account and in this case, the Trade Account Monitor will only show the account to which that installation is connected. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-15 17:43:18] |
yes sorry , i was able to figure it out. i was using the trade account filter thats why only one was visible
| [2026-01-08 14:18:46] |
Hi, Can accounts with multiple FCM tied to same sierrachart login/account ? Thanks |
| [2026-01-08 16:36:41] |
If the accounts are with multiple FCMs then you would have to use different credentials to access each account. As such, you will only see the account to which a Sierra Chart installation is connected to at that time. To use Sierra Chart with multiple FCMs, we recommend using a separate installation of Sierra Chart for each connection. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart The only thing you need to be aware of with the multiple installations is that the exchanges only allow for a total of three different installations accessing the data. So if you need more than 3 connections, the best solution is to use a second computer, in which case you do have to pay a second set of exchange fees. Refer to the following: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-08 16:42:42] |
Do you mean different sierrachart credentials ? |
| [2026-01-08 17:09:33] |
No, we do not mean different Sierra Chart credentials. We mean different credentials for the trading accounts. An installation of Sierra Chart can only be connected to a single trading service with a single Username/Password pair that are used to login. If that Trading Service Username/Password pair has multiple trading accounts associated with it, then those will show in the Trade Account list in your Trade Window. But, if you need to use different credentials to access different trading accounts, then you should use multiple installations of Sierra Chart so you can be connected to each account all the time, and not get confused on which one you are connected to at any given moment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-08 17:16:51] |
I understand that but my question is can all the FCM i have account with, be able to login in the same sierrachart account and have teton routing. Eg. FCM A -> Sierra account X -> Installation 1 FCM B -> Sierra Account X -> Installation 2 |
| [2026-01-08 17:33:24] |
There are no restrictions on how many FCM accounts you can access with a single Sierra Chart account. The only item of concern is related to the data as we noted previously. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-20 14:30:21] |
Hi, If trade position limit is 2 and order quantity limit is 4 , then what would happen if a market order of 4 is sent? will it reject or will it try to execute 2 contracts and reject the remaining 2? |
Private File |
| [2026-01-20 16:52:09] |
Any order that would cause either item to be exceeded will be rejected. Refer to the information at the following link and the one below it: Global Symbol Settings: Trade Position Limit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
