Date/Time: Wed, 25 Nov 2026 16:38:59 +0000
Imbalances
View Count: 466
[2025-07-14 18:24:31]
User119701 - Posts: 3
[image: image.png]
[image: image.png]
[image: image.png]
Based on my settings why cant i see green and purple texts?
imagetmp_1752472514_image.png / V - Attached On 2025-07-14 18:24:20 UTC - Size: 474.85 KB - 291 views
imagetmp_1752472513_image.png / V - Attached On 2025-07-14 18:24:23 UTC - Size: 130.79 KB - 279 views
imagetmp_1752472511_image.png / V - Attached On 2025-07-14 18:24:26 UTC - Size: 289.93 KB - 200 views
[2025-07-14 18:24:58]
The Numbers Bars study allows you to have up to 3 columns of data. The first column you have configured to show the Bid x Ask numbers and to color the background according to the colors setup for Column 1.
You do not have anything setup to display in Column 2, so that is why the green and purple coloring is not seen. If you want to color the data in Column 1, then you need to change that columns colors. Refer to the following:
Numbers Bars: Column # Range 3 Up Color
