Date/Time: Tue, 17 Nov 2026 18:09:14 +0000
Live data not working despite Teton CME + Denali subscription
View Count: 691
[2025-07-10 17:43:40]
User994206 - Posts: 1
I have an active Service Package 11 with Denali Exchange Data and Teton CME Routing, connected via AMP Futures. I am subscribed to real-time CME data (NQ, MNQ), and everything appears correctly set up on AMP's side.
However, my charts are still displaying "delayed" next to the symbols (e.g. NQU25_FUT_CME[M], MNQU25_FUT_CME[M]). Even when the candles update momentarily, the chart freezes and does not stream data properly.
Could you please check if everything is correctly enabled for real-time data on your end, and confirm if I’m using the correct symbol format for Teton with Denali?
Thank you very much in advance!
[2025-07-10 19:48:18]
John - SC Support - Posts: 48555
Everything looks good in your account, and those are the correct symbols.
Please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
