Date/Time: Tue, 17 Nov 2026 18:08:47 +0000
Live Data Feed Issues
View Count: 738
[2025-07-03 11:49:18]
Kadodia12 - Posts: 44
Hi my live data isn't coming through on my chart and I haven't changed anything.
I have to keep refreshing the connection or selecting 'delete and download data' to see new data.
Pls tell me how to fix this.
[2025-07-03 12:00:12]
Sierra_Chart Engineering - Posts: 25432
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2025-07-03 12:10:46]
I have followed the instructions for clearing the windows log and have send the log for analysis, after disconnecting and reconnecting to the data feed
[2025-07-03 12:51:01]
Hi is this being investigated? the issue still persists
[2025-07-03 13:29:22]
Re-opening the chartbook after closing it (using NQU5 symbol) is taking extremely long also. Not sure if the problem is related but needs resolving ASAP pls.
[2025-07-03 13:53:42]
Not sure if my log I sent was received as nobody confirmed, so copying it in here also.
2025-07-03 09:48:54.310 | Trade activity files set size: 2594
2025-07-03 09:48:54.324 | Rithmic Direct - DTC | Processed connection points. Count: 369
2025-07-03 09:48:54.325 | Error getting address info for downloads.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:48:54.374 | Reading Internal Order ID file.
2025-07-03 09:48:54.376 | Reading Trade Orders file.
2025-07-03 09:48:54.377 | Reading Trade Positions file.
2025-07-03 09:48:54.378 | Reading Trade Account Data files.
2025-07-03 09:48:54.390 | Software version: 2758 64-bit
2025-07-03 09:48:54.390 | Primary Thread ID: 7768
2025-07-03 09:48:54.390 | Usage end date: 2025-07-23
2025-07-03 09:48:54.390 | Enabled for: Advanced Features 2.
2025-07-03 09:48:54.390 | Enabled for: Sierra Chart Historical Data Service.
2025-07-03 09:48:54.390 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-07-03 09:48:54.390 | Enabled for: Delayed Denali Exchange Data Feed.
2025-07-03 09:48:54.390 | Enabled for exchange2: CME (Trading Account Required)
2025-07-03 09:48:54.390 | Enabled for exchange2: CBOT (Trading Account Required)
2025-07-03 09:48:54.390 | Enabled for exchange2: COMEX (Trading Account Required)
2025-07-03 09:48:54.390 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-07-03 09:48:54.390 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-07-03 09:48:54.390 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-07-03 09:48:54.390 | Custom symbol settings values: enabled
2025-07-03 09:48:54.390 | Chart Update Interval: 500
2025-07-03 09:48:54.390 | Intraday Data Storage Time Unit: 1
2025-07-03 09:48:54.390 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2025-07-03 09:48:54.390 | 2025-07-03 13:48:54 Local computer time in UTC
2025-07-03 09:48:54.390 | 2025-07-03 09:48:54 Local computer time in SC Time Zone
2025-07-03 09:48:54.390 | Program path: C:\SierraChart2\
2025-07-03 09:48:54.390 | Data Files path: C:\SierraChart2\Data\
2025-07-03 09:48:54.390 | OS Version Number: 10.0
2025-07-03 09:48:54.390 | Locale Setting: C
2025-07-03 09:48:54.397 | DLLs: UserContributedStudies_64.dll
2025-07-03 09:48:54.397 | Allowed protected custom studies:
2025-07-03 09:48:54.397 | Crash reporter started: true
2025-07-03 09:48:54.397 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2025-07-03 09:48:54.441 | Mapping MNQU5.CME to MNQU25. Service code: cme
2025-07-03 09:48:54.441 | Using symbol data fast lookup vector
2025-07-03 09:48:54.465 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (3) | CloseSocket call.
2025-07-03 09:48:54.465 | Rithmic Direct - DTC | HTTP response receiving connection points not completed or OK.
2025-07-03 09:48:55.227 | Symbol settings MD5 received. Request ID: 1.
2025-07-03 09:48:55.227 | Symbol settings are up-to-date for rithmic_v2.trading.
2025-07-03 09:48:56.841 | Received 5 login tokens.
2025-07-03 09:48:58.892 |
2025-07-03 09:48:58.892 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:48:58.892 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:48:58.895 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:10.915 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:10.915 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:10.915 | Rithmic Direct - DTC | Failed connections: 1
2025-07-03 09:49:10.915 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:10.915 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:10.931 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:10.931 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:10.931 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:14.923 |
2025-07-03 09:49:14.923 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:14.923 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:14.923 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:14.925 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:14.926 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:14.926 | Rithmic Direct - DTC | Failed connections: 2
2025-07-03 09:49:14.927 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:14.927 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:14.940 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:14.940 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:14.940 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:18.948 |
2025-07-03 09:49:18.948 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:18.948 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:18.948 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:18.949 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:18.949 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:18.949 | Rithmic Direct - DTC | Failed connections: 3
2025-07-03 09:49:18.949 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:18.949 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:18.964 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:18.964 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:18.964 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:22.953 |
2025-07-03 09:49:22.953 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:22.953 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:22.953 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:29.919 | NQU5.CME #37 | Reloading chart.
2025-07-03 09:49:29.959 | NQU5.CME [CBV] #1 | Reloading chart.
2025-07-03 09:49:29.982 | Starting DelayedDownloadMonitoringTimer
2025-07-03 09:49:29.982 | Starting HDTimeoutTimer
2025-07-03 09:49:29.982 | Added historical Intraday data request for NQU5.CME to the queue.
2025-07-03 09:49:29.983 | Triggering next historical data download in queue.
2025-07-03 09:49:29.985 | NQU5.CME [CBV] #1 | Performing continuous chart historical Daily data download for symbol NQU5.CME starting at last date in file.
2025-07-03 09:49:29.985 | Starting DelayedDownloadMonitoringTimer
2025-07-03 09:49:29.985 | Starting HDTimeoutTimer
2025-07-03 09:49:29.985 | Added historical Daily data request for NQU5.CME to the queue.
2025-07-03 09:49:29.986 | Triggering next historical data download in queue.
2025-07-03 09:49:30.088 | NQU5.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-07-03 09:49:30.334 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 | Reloading chart.
2025-07-03 09:49:30.472 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2025-07-03 09:49:30.484 | NQU5.CME #37 | StartDateTimeForLoadingOrderFills: 2024-06-26 00:00:00
2025-07-03 09:49:30.485 | NQU5.CME #37 | Chart data loading complete.
2025-07-03 09:49:30.485 | Mapping NQU5.CME to NQU25. Service code: cme
2025-07-03 09:49:30.486 | HD Request # 1 | Downloading Intraday chart data for NQU5.CME to the file NQU5.CME.scid. Service: cme
2025-07-03 09:49:30.486 | HD Request # 1 | Download start date-time: 2025-07-03 09:48:39.000000. File last date-time: 2025-07-03 09:48:39.000000
2025-07-03 09:49:30.486 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2025-07-03 09:49:30.489 | HD Request # 2 | Downloading Historical Daily chart data for NQU5.CME. Starting date: 2025-06-30. Service: rithmic.trading
2025-07-03 09:49:34.984 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:34.984 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:34.984 | Rithmic Direct - DTC | Failed connections: 4
2025-07-03 09:49:34.984 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:34.984 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:34.984 | Error getting address info for ds28.sierracharts.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:34.984 | Socket (2) | CloseSocket call.
2025-07-03 09:49:34.984 | Socket (0) | CloseSocket call.
2025-07-03 09:49:34.985 | HD Request # 1 | Error downloading historical Intraday data for NQU5.CME. The network socket has been closed. Retrying download.
2025-07-03 09:49:34.985 | Added historical Intraday data request for NQU5.CME to the queue.
2025-07-03 09:49:34.985 | Triggering next historical data download in queue.
2025-07-03 09:49:34.985 | Historical data download thread signaled to stop.
2025-07-03 09:49:34.986 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQU5.CME
2025-07-03 09:49:34.986 | HD Request # 1 | Completion time: 4s.
2025-07-03 09:49:34.986 | HD Request # 3 | Downloading Intraday chart data for NQU5.CME to the file NQU5.CME.scid. Service: cme
2025-07-03 09:49:34.987 | HD Request # 3 | Download start date-time: 2025-07-03 09:48:39.000000. File last date-time: 2025-07-03 09:48:39.000000
2025-07-03 09:49:34.987 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2025-07-03 09:49:34.988 | Socket (1) | Creating socket.
2025-07-03 09:49:34.988 | Socket (1) | New receive buffer size: 0
2025-07-03 09:49:34.988 | Socket (1) | Connecting to IP: 69.39.70.248.
2025-07-03 09:49:34.999 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:34.999 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:34.999 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:35.222 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-07-03 09:49:35.222 | HD Request # 3 | Sending historical data logon request message.
2025-07-03 09:49:35.384 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-07-03 09:48:39. Record interval: 1. Symbol: NQU25
2025-07-03 09:49:35.496 | HD Request # 3 | Decompressing data.
2025-07-03 09:49:35.913 | HD Request # 3 | Receiving Intraday data for NQU5.CME starting at 2025-07-03 09:48:39.113000
2025-07-03 09:49:35.914 | Socket (1) | CloseSocket call.
2025-07-03 09:49:35.914 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-07-03 09:49:35.914 | Historical data download thread signaled to stop.
2025-07-03 09:49:35.914 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-07-03 09:48:39.113000.
2025-07-03 09:49:35.914 | HD Request # 3 | Received 54 Intraday data records from 2025-07-03 09:48:39.113000 to 2025-07-03 09:49:32.212000 (53.1 seconds. Delay: 3.7 seconds) and wrote 54 records for NQU5.CME
2025-07-03 09:49:35.915 | HD Request # 3 | Completion time: 1s.
2025-07-03 09:49:35.915 | HD Request # 3 | Intraday data download complete for NQU5.CME. Unique request ID: 1
2025-07-03 09:49:35.915 | Removing historical data download ID 1.
2025-07-03 09:49:35.915 | Real-time Intraday chart data file updates started for NQU5.CME
2025-07-03 09:49:35.928 | Opened cached Intraday file: C:\SierraChart2\Data\NQU5.CME.scid. Thread ID: 7768
2025-07-03 09:49:35.929 | Intraday chart data file opened for NQU5.CME
2025-07-03 09:49:35.929 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-07-03 09:49:35.929 | No download requests in the queue to start downloads for.
2025-07-03 09:49:35.929 | Historical data for NQU5.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-07-03 09:49:36.031 | Socket (1) | Socket gracefully closed by remote side.
2025-07-03 09:49:36.031 | Socket (1) | Closed.
2025-07-03 09:49:36.259 | HD Request # 2 | Requesting historical Daily data for NQU25 starting at 2025-06-29. SC External HD service.
2025-07-03 09:49:36.259 | HD Request # 2 | Error downloading historical Daily data for NQU5.CME. HTTP error when downloading from SC external historical data service. Status code: 0. Failed
2025-07-03 09:49:36.259 | HD Request # 2 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQU5.CME
2025-07-03 09:49:36.259 | HD Request # 2 | Completion time: 6s.
2025-07-03 09:49:36.259 | HD Request # 2 | Daily data download complete for NQU5.CME. Unique request ID: 2
2025-07-03 09:49:36.259 | Removing historical data download ID 2.
2025-07-03 09:49:36.259 | No download requests in the queue to start downloads for.
2025-07-03 09:49:36.432 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load.
2025-07-03 09:49:36.432 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 | Reloading chart.
2025-07-03 09:49:36.561 | NQU5.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load.
2025-07-03 09:49:36.562 | NQU5.CME [CBV] #1 | Reloading chart.
2025-07-03 09:49:36.921 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 | Reloading chart.
2025-07-03 09:49:37.166 | NQU5.CME [CBV] #1 | Reloading chart.
2025-07-03 09:49:38.996 |
2025-07-03 09:49:38.996 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:38.996 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:38.996 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:38.997 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:38.997 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:38.997 | Rithmic Direct - DTC | Failed connections: 5
2025-07-03 09:49:38.997 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:38.997 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:39.012 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:39.013 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:39.013 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:43.022 |
2025-07-03 09:49:43.022 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:43.022 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:43.022 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:43.023 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:43.024 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:43.024 | Rithmic Direct - DTC | Failed connections: 6
2025-07-03 09:49:43.024 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:43.024 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:43.038 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:43.038 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:43.038 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:47.040 |
2025-07-03 09:49:47.040 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:47.040 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:47.040 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:49:47.042 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:49:47.042 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:49:47.042 | Rithmic Direct - DTC | Failed connections: 7
2025-07-03 09:49:47.042 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:49:47.042 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:47.058 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:49:47.058 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:49:47.058 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:49:51.048 |
2025-07-03 09:49:51.048 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:49:51.048 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:49:51.048 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:50:03.102 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:50:03.103 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:50:03.103 | Rithmic Direct - DTC | Failed connections: 8
2025-07-03 09:50:03.103 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:50:03.103 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:03.122 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:50:03.122 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:50:03.122 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:07.124 |
2025-07-03 09:50:07.124 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:50:07.124 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:50:07.124 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:50:07.125 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:50:07.125 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:50:07.125 | Rithmic Direct - DTC | Failed connections: 9
2025-07-03 09:50:07.125 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:50:07.125 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:07.140 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:50:07.140 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:50:07.140 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:08.073 | NQU5.CME [CBV] #1 Record has been filtered due to large range while loading Intraday data for NQU5.CME *
2025-07-03 09:50:11.148 |
2025-07-03 09:50:11.148 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:50:11.148 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:50:11.148 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:50:23.179 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:50:23.179 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:50:23.179 | Rithmic Direct - DTC | Failed connections: 10
2025-07-03 09:50:23.179 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:50:23.179 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:23.194 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:50:23.194 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:50:23.194 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:27.191 |
2025-07-03 09:50:27.191 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:50:27.191 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:50:27.191 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:50:39.237 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:50:39.238 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:50:39.238 | Rithmic Direct - DTC | Failed connections: 11
2025-07-03 09:50:39.238 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:50:39.238 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:39.253 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:50:39.253 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:50:39.253 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:43.249 |
2025-07-03 09:50:43.250 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:50:43.250 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:50:43.250 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:50:50.126 | NQU5.CME/MNQU5.CME [CBV] 500 Volume #2 Record has been filtered due to large range while loading Intraday data for NQU5.CME *
2025-07-03 09:50:55.295 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:50:55.295 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:50:55.295 | Rithmic Direct - DTC | Failed connections: 12
2025-07-03 09:50:55.295 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:50:55.295 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:55.312 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:50:55.312 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:50:55.312 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:50:59.325 |
2025-07-03 09:50:59.325 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:50:59.325 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:50:59.325 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:11.348 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:11.348 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:11.348 | Rithmic Direct - DTC | Failed connections: 13
2025-07-03 09:51:11.348 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:11.348 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:11.363 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:11.363 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:11.363 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:15.406 |
2025-07-03 09:51:15.406 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:15.406 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:15.406 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:15.408 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:15.427 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:15.427 | Rithmic Direct - DTC | Failed connections: 14
2025-07-03 09:51:15.427 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:15.427 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:15.433 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:15.433 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:15.433 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:19.427 |
2025-07-03 09:51:19.427 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:19.427 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:19.427 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:27.468 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:27.468 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:27.468 | Rithmic Direct - DTC | Failed connections: 15
2025-07-03 09:51:27.468 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:27.468 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:27.482 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:27.482 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:27.482 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:31.486 |
2025-07-03 09:51:31.486 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:31.486 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:31.486 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:31.487 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:31.487 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:31.487 | Rithmic Direct - DTC | Failed connections: 16
2025-07-03 09:51:31.487 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:31.487 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:31.500 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:31.500 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:31.500 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:35.500 |
2025-07-03 09:51:35.500 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:35.500 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:35.500 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:43.551 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:43.551 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:43.551 | Rithmic Direct - DTC | Failed connections: 17
2025-07-03 09:51:43.551 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:43.551 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:43.559 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:43.559 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:43.559 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:47.565 |
2025-07-03 09:51:47.565 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:47.565 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:47.565 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:47.567 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:47.567 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:47.567 | Rithmic Direct - DTC | Failed connections: 18
2025-07-03 09:51:47.567 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:47.567 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:47.581 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:47.581 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:47.581 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:51.577 |
2025-07-03 09:51:51.578 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:51:51.578 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:51:51.578 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:51:59.603 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:51:59.603 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:51:59.603 | Rithmic Direct - DTC | Failed connections: 19
2025-07-03 09:51:59.603 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:51:59.603 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:51:59.618 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:51:59.618 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:51:59.618 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:03.618 |
2025-07-03 09:52:03.618 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:03.618 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:03.618 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:03.618 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:03.619 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:03.619 | Rithmic Direct - DTC | Failed connections: 20
2025-07-03 09:52:03.619 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:03.619 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:03.634 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:03.634 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:03.634 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:07.633 |
2025-07-03 09:52:07.633 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:07.633 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:07.633 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:15.690 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:15.690 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:15.690 | Rithmic Direct - DTC | Failed connections: 21
2025-07-03 09:52:15.690 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:15.690 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:15.704 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:15.704 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:15.704 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:19.704 |
2025-07-03 09:52:19.705 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:19.705 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:19.705 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:19.705 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:19.706 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:19.706 | Rithmic Direct - DTC | Failed connections: 22
2025-07-03 09:52:19.706 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:19.706 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:19.720 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:19.720 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:19.720 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:23.721 |
2025-07-03 09:52:23.721 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:23.721 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:23.721 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:31.763 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:31.763 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:31.763 | Rithmic Direct - DTC | Failed connections: 23
2025-07-03 09:52:31.763 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:31.763 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:31.778 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:31.778 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:31.778 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:35.778 |
2025-07-03 09:52:35.778 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:35.778 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:35.778 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:35.779 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:35.779 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:35.779 | Rithmic Direct - DTC | Failed connections: 24
2025-07-03 09:52:35.779 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:35.779 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:35.794 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:35.794 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:35.794 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:39.803 |
2025-07-03 09:52:39.803 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:39.803 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:39.803 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:47.848 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:47.848 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:47.848 | Rithmic Direct - DTC | Failed connections: 25
2025-07-03 09:52:47.848 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:47.848 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:47.864 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:47.864 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:47.864 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:51.863 |
2025-07-03 09:52:51.863 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:51.864 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:51.864 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-07-03 09:52:51.864 | Error getting address info for rsc.rithmic.com. Windows error code 11001: No such host is known. *
2025-07-03 09:52:51.864 | DTC Client socket (1) | CloseSocket call.
2025-07-03 09:52:51.865 | Rithmic Direct - DTC | Failed connections: 26
2025-07-03 09:52:51.865 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-07-03 09:52:51.865 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:51.879 | DTC Client socket (0) | CloseSocket call.
2025-07-03 09:52:51.879 | Rithmic Direct - DTC | Disconnected.
2025-07-03 09:52:51.879 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-07-03 09:52:55.880 |
2025-07-03 09:52:55.880 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-07-03 09:52:55.880 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-07-03 09:52:55.880 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
[2025-07-03 14:26:35]
hello is anyone there??
[2025-07-03 15:44:45]
John - SC Support - Posts: 48555
Your log shows that your computer is not translating the information correctly for the Rithmic servers. Please follow the instructions at this link (Just the item in Step #5):
https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#DomainNameServiceIssues
Or you can reboot your computer.
If that does not resolve the problem, then try a different Rithmic server and let us know if you continue to have an issue.
[2025-07-05 19:38:21]
What happens now (before trying the steps you've mentioned) is that the chartbook just takes forever to load and eventually stalls. So I think the problem isn't the DNS any longer. It seems to be the instance of Sierra Charts I'm running. I have a separate instance on the same laptop that runs without issues.
[2025-07-07 17:10:04]
You can not connect to the same Rithmic account with more than one installation of Sierra Chart. This is a limitation of the connectivity between Rithmic and Sierra Chart that is owned by Rithmic.
