Date/Time: Wed, 25 Nov 2026 20:51:50 +0000
Enhancement to Chart Values tools
View Count: 478
| [2025-06-27 13:02:13] |
| BenjaminR - Posts: 185 |
When using the chart values tools/crosshairs- it would be very useful to display the range of the bar (specifically daily) when hovering over it. Can we get this on the list? I currently export the H/L & other data to a .tsv, then import it into Excel & it is calculated there, & I use it comparatively for specific purposes & discerning a certain market condition- but this is not always practical, especially when I'm setting up new instruments, as I need to track a number of days. it would be very helpful & timesaving to be able to look back over days without manually calculating the value for each bar- it's also easy to lose my place with the crosshairs when doing this. Thank you! |
| [2025-06-27 13:50:19] |
| John - SC Support - Posts: 48658 |
The workaround for this is to add the "True Range" study to the chart (or whatever study you want to give you the range) which will give you the information in the Tool Values Window. You can hide the study if you do not want to see the information on the screen, in this case you will need to enable the option for "Display Values When Hidden" on the Subgraphs tab. Refer to the following: Chart Studies: Subgraphs Tab >> Display Values When Hidden For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-27 14:32:39] |
Perfect! Thank you, John- you're the best!
| [2025-06-28 20:01:04] |
| Sierra_Chart Engineering - Posts: 25483 |
We will working on adding this field as an option.
