Date/Time: Wed, 25 Nov 2026 21:06:06 +0000
[User Discussion] - Export NQ chart data
View Count: 844
[2025-06-14 17:26:59]
User598372 - Posts: 12
I want to export NQ 375 vol intraday data to a (txt) file 1 month at a time. Jan_2025_NQ.txt would have all of the 375 vol chart data from 1-1-2025 to 1-31-2025. I want that for every month.
Can't figure it out.
imageSC 375 vol.png / V - Attached On 2025-06-14 17:24:50 UTC - Size: 49.93 KB - 308 views
[2025-06-16 14:41:51]
John - SC Support - Posts: 48659
In general, you would need to setup a chart with just the 1 month of data loaded by using the "Load Data Limiting Method: Date Range" settings. Then export the data using "Edit >> Export Bar Data to Text File". Refer to the following:
Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu)
Edit Menu: Edit >> Export Bar Data to Text File
Where things get tricky is how you are going to handle the different contracts. You can either setup a Continuous Futures Contract chart and use that directly, or you would need to determine how to export the data you want for each individual contract. You can open a chart for older contracts by typing in the name directly on the Find Symbol window. Refer to the following:
Chart Settings: Continuous Contract (Chart >> Chart Settings >> Symbol >> Symbol menu)
