Date/Time: Wed, 25 Nov 2026 21:06:23 +0000
level2 big bid/ask size alert
View Count: 1616
[2025-06-09 18:41:06]
User793936 - Posts: 17
Hello, i want to create alerts when a stock has 100000 (typicaly you can see this in bid/ask like 1000)> number of shares on the best bid/ask
I have cheked quote board when I can put stock that i'm interested and, and there is column bid size and ask size.Is this possible to have alerts when on a stock will be big size on ask/bid?
[2025-06-09 21:22:34]
John - SC Support - Posts: 48659
The "Depth of Market" study gives the current Best Bid and Best Ask sizes, so you can use this study to get what you want. Refer to the following (note that for what you are wanting, you do not need to use the Spreadsheet Study - just reference the Bid Size and Ask Size subgraphs):
Depth of Market Data
Study/Chart Alerts And Scanning: Referencing Study Subgraphs
And also review the other information on the Alerts page for how to setup alerts.
[2025-06-10 17:35:05]
Thank you for response.
I have read the links you have given me. I understood that for my purpose I need to go to the chart studies - “depth of market data” - then go to the "alerts" section and in the "alert condition" tab write a formula to trigger alerts? I ran into a problem that I did not see a variable on this page https://www.sierrachart.com/index.php?page=doc%2FStudyChartAlertsAndScanning.php#BaseGraphIdentifiers so I could specify the bid/ask size ?
what should I write in the alert condition section?
My goal is to have an alert as soon as the best bid/ask just shows more than a certain number that I want to specify myself.
Translated with DeepL.com (free version)
[2025-06-10 17:40:59]
Add the "Depth of Market" study to you chart. Follow these instructions to do this:
Chart Studies: Adding/Modifying Chart Studies
On the Settings window for the Depth of Market study, select the "Alerts" tab.
Enter the following in the "Alert Condition" field to get an alert when the Best Bid is greater than 100:
=SG1 > 100
SG1 is the "Bid Size" subgraph that contains the information for the Best Bid. SG2 is the subgraph for the Ask Size.
Expand on the formula as you need for what you want to do.
[2025-06-12 11:12:56]
I did as you said unfortunately it didn't work. I used another study and then it worked.
Now I have next goal - I want to get the same alerts, but not from charts. I want it to be from some list where I will add stocks that I am interested in, and from there the alerts will appear. How to do this? thank you !
[2025-06-12 17:03:52]
Refer to the following:
Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols
[2025-06-13 10:32:07]
the problem with this method is that having a list of stocks in the watchlist, there is no constant scanning on all assets at the same time.between passing from 1 to 100 chart, there will be time for which the signal can appear and disappear and it will not get into the alert, and I will miss signal.
so this option is not suitable, it is important to have a list of stocks, and that the scanning was constant, simultaneously on all stocks that are in the list, how can I do it?
Date Time Of Last Edit: 2025-06-13 12:03:26
[2025-06-13 13:25:32]
You would need to open charts for all the symbols you want. You can hide the charts and you will still get the alerts.
[2025-06-20 11:20:28]
Hi, can I get the same from spreadsheet study? put list of stock into spreadsheet or watchlist and from there to have, constant scanning for alerts. This is a necessary need because the list of stocks is constantly changing, doing it through a chart is not optimal for me. I would like to be able to scan it through whatchlist and then sort the list of stocks by volume or price or other parameter ?
[2025-06-20 15:09:54]
This can not be done through a Spreadsheet Study or the Quote Board, since you are wanting to test against a very specific item (the Best Bid/Best Ask). If you were wanting to alert on Total Volume, or a Price Point, or something similar, then you could use the Quote Board. Refer to the following:
Alerts Manager: Symbol Alerts
