Date/Time: Wed, 25 Nov 2026 21:06:06 +0000
cant get options list
View Count: 842
[2025-06-02 19:46:32]
Rnn - Posts: 84
Since today I cant get the options list after pressing "get options" on the selected symbol (ESM25-CME)
[2025-06-02 21:32:38]
John - SC Support - Posts: 48659
We are not seeing any issue with this at the moment. Although we are only getting 4 options showing for ESM25-CME. Keep in mind that the only options that are shown are those with Open Interest. We wonder if the timing of when you selected the option was such that the Open Interest had not updated, so there was nothing to show.
Let us know if you are still not getting anything in the list of options.
[2025-06-03 09:04:12]
Rnn - Posts: 84
its back to normal now - full list
[2025-06-08 22:06:21]
Rnn - Posts: 84
I have a problem with it again, now when I press get options it doesn't do anything at all, not even showing a list
[2025-06-08 22:07:41]
We are checking on this.
[2025-06-09 18:51:24]
Rnn - Posts: 84
still the same
[2025-06-10 13:48:42]
What is the symbol that you have selected that you are trying to get options for? So we can test.
[2025-06-11 14:11:32]
Rnn - Posts: 84
ESM25-CME
list is now back but i'm not able to get the data - getting "historical intraday data failed"
Date Time Of Last Edit: 2025-06-11 14:12:28
[2025-06-11 16:55:21]
We understand the reason for the problem. This is now resolved and we apologize for this. Sorry for the delay.
It related to using a much tighter symbol pattern for options in order to make data management reliable.
This caused a symbol mapping issue which is now resolved.
There still is an outstanding issue regarding the download starting date which we will be working on today. But should not cause a problem.
Follow these instructions on your side:
[2025-06-11 19:03:06]
Rnn - Posts: 84
I pressed on "update from server" and ok after, should I do more other than that? what is it for?
"There still is an outstanding issue regarding the download starting date which we will be working on today. But should not cause a problem." - u mean the historical data for each option?
options are now loading, but the charts are irrelevant for all of the historical data - there are almost no candles
if I load an option the only candles I see are from now and some few candles from the past
[2025-06-16 13:09:09]
Rnn - Posts: 84
Hi, anything new with it?
all of the options still don't have historical data
[2025-06-16 13:47:00]
Regarding options historical data, refer to:
Changes to CME Group Options Historical Data
You just need to do this once:
Date Time Of Last Edit: 2025-06-16 13:47:55
[2025-06-16 17:41:22]
Rnn - Posts: 84
thanks, notice that u need to do delete and download data from the oldest candle for each option to get the full chart
Date Time Of Last Edit: 2025-06-16 17:42:05
[2025-06-16 17:47:57]
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
