Date/Time: Wed, 25 Nov 2026 21:06:06 +0000
[Locked] - Changes to CME Group Options Historical Data
View Count: 4396
| [2025-06-06 10:38:20] |
| Sierra_Chart Engineering - Posts: 25483 |
Effective Friday, June 6, 2025, there are server changes for CME Group historical Options data (both daily and Intraday). To be able to access historical data for CME Group Options requires that you run version 2762 or higher. Version 2762 is now available. Follow the instructions here to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-06 12:45:49
| [2025-06-06 13:54:33] |
We had to remove version 2762 as there is a problem with this version. Only version 2761 is available. The changes related to options regarding historical data is in order to maintain the best system performance, for futures and spreads. Options data is barely used by our users but yet, does consume a significant amount of processing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-16 13:45:16] |
For options historical data, use version 2765 or higher. Instructions: Software Download: Fast Update Currently this is a Prerelease. So update to the Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-16 13:46:15
