Date/Time: Wed, 25 Nov 2026 21:35:54 +0000
How do I create this type of profile on the DOM?
View Count: 802
| [2025-05-29 18:17:13] |
| jsandlan - Posts: 99 |
I've attached a screenshot for what looks like a Bid / Ask Volume Profile - where the shape is determined by volume at different prices. If this is not what is being signified by this study - I am open to learning about what it actually is but this is my understanding. My question is, based on the attached picture, how do I add this type of profile to my DOM? Thanks. |
| [2025-05-29 18:34:34] |
We can not say what exactly this is, as it could one of two possible things. 1. If this is actually in the DOM, then it is a pair of columns with the profiles turned on and one set to display left and the other right. Refer to the following: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) 2. This could be a Numbers Bars chart showing the Bid and Ask volumes with the Background Type set to one of the "Split" options. Refer to the following: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
