Date/Time: Wed, 25 Nov 2026 16:25:06 +0000
changing the "chart drawing properties" of a line
View Count: 794
| [2025-05-27 17:59:35] |
| michelm - Posts: 1 |
Hello, I apologize in advance for my English, I use Google Translate. Can you please show me how you change the "chart drawing properties" of a line for example. Which will be displayed not in the form of tables Thank you very much |
| [2025-05-27 20:39:01] |
The window that you show in the image is the properties window for a chart drawing in Sierra Chart. We are removing reliance on Microsoft Windows, therefore we have created our own windows, and that is one of them. If you need help with how to use those windows, refer to the following: Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-21 15:45:41] |
| OasisCap - Posts: 4 |
Good morning. I was looking for a thread regarding the changes made to the properties window for chart drawings, and was wondering why the window format changed? Is there anyway that you could go back to the old format? I see that you mentioned something about removing reliance on Windows, but the new format is very cumbersome, and less user friendly, especially when trying to quickly make adjustments during a live market. I can only speak for myself, but compared to what it used to look like, and other charting platforms, it makes things more complicated. Thank you |
| [2025-10-21 16:13:04] |
This is the new format that we are using for all windows going forward. There is no option to change to the other format. There are a number of options that you can set for these new windows. Refer to the following: General Settings Window: Settings Windows (Global Settings >> General Settings) Settings Windows Interface For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
