Date/Time: Wed, 25 Nov 2026 21:46:12 +0000
Alert is being triggered multiple times
View Count: 720
| [2025-05-17 13:48:01] |
| sadramistes - Posts: 24 |
Hi, when i set an alert i tick the box for the alert to be triggered only once. However, every time the price touches the alert level i get an alert. That is annoying as i get spammed with alerts. Is there a way to fix it? I use heikaneshi bars. Thank you |
| [2025-05-19 09:31:22] |
| Sierra_Chart Engineering - Posts: 25483 |
Is this a Symbol Alert?: Alerts Manager: Symbol Alerts Additionally, the alert will be configured to use a specific Alert Number. Check the Number of Times that alert number is set to play: General Settings Window: Alerts (Global Settings >> General Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-19 09:31:31
| [2025-05-19 10:05:35] |
It got triggered yesterday on drawing alert but today i tried it both on drawing alert and as a symbol alert and it works fine. it got triggered only once. I checked the global settings just in case and they look ok. thank you for your answer. everything looks ok now. |
