Date/Time: Wed, 25 Nov 2026 21:46:04 +0000
Which Package should I buy?
View Count: 5826
| [2025-05-12 19:47:20] |
| User552609 - Posts: 3 |
I would like to use Market & volume profiles + Trading using the DOM. I looked at the package info but I'm still not sure which one I should take for my use. Thank you for your help! Date Time Of Last Edit: 2025-05-12 19:56:57
| [2025-05-12 21:45:18] |
You need to be on one of the "Advanced" packages in order to be able to use the TPO (Market Profile) feature. Since you state that you will be trading from the DOM, then you will also need to be on one of the "Integrated" packages. Therefore, from what you have given us, the lowest price package option is the "Integrated Advanced" package. Refer to the information here: Description of Service Packages and Pricing: Integrated Sierra Chart with Advanced Features (Service Package 11) To change to a paid package follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-12 22:27:01] |
Can you confirm please : that I would be able to trade both CME and Eurex on the DOM using that package. Thank you! |
| [2025-05-13 02:03:20] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes you will.
| [2025-05-14 14:52:03] |
Sorry, I wasn't clear enough I think! I mean the data for both exchanges are comprise in the package? |
| [2025-05-14 16:35:23] |
The data is a separate fee. You do need to be on an Integrated package in order to have access to the data, but you need to setup, activate, and pay for the CME Group and EUREX exchanges you want. For the CME Group, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For EUREX, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
