Date/Time: Sat, 18 May 2024 15:57:23 +0000
Importing chartbook during free trial
View Count: 51
[2024-05-01 16:06:08] |
User360727 - Posts: 1 |
Hi, I imported a chartbook and opened it, but the chart is blank. Is this because the free trial does not support this or am I doing something wrong? Thanks
[2024-05-01 18:47:23] |
There are a few items at work here. First, your trial has not been activated, therefore you are limited in the symbols that you can use. Refer to the following: Sierra Chart Trial Account and Account Activation: Introduction The other item is that the Chartbook may be setup to use a different symbology than what you are setup for. To remedy this, open the chartbook and select "Edit >> Translate Symbols to Current Service". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
