Date/Time: Sat, 18 May 2024 10:21:32 +0000
Change the Pivot Points formula
View Count: 56
[2024-04-30 17:58:12] |
User333599 - Posts: 4 |
The formula for Pivot Points needs to be modified. How can I achieve this?
[2024-04-30 18:45:50] |
You can not change it directly. But you could use the Arithmetic Studies, or the Spreadsheet Formula to modify a single subgraph for the Pivot Points to be the way you want. If you need to change multiple pivot points then we would recommend doing this through the Spreadsheet Study. Refer to the following: Using the Basic Arithmetic Studies Spreadsheet Formula Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
