Date/Time: Sat, 18 May 2024 10:42:35 +0000
Hello - Requesting a feature to allow user to define height of a subregion
View Count: 92
[2024-04-30 12:06:14] |
HumblyTrading - Posts: 171 |
Hello SierraChart team, When using many charts of different instruments and timeframes, I find myself adjusting the heights of each subregion on each chart to get them to line up visually. I wonder if you would consider adding a feature to the scale or the settings which would allow users to define the height of each subregion, perhaps as a % of the region 1, and/or as a pixel or other measurement you see fit. Thank you for your consideration, Mike |
[2024-04-30 16:00:00] |
If you setup a Study Collection and apply it to a chart, then it will use the heights of the regions set as they were when you saved the study collection. Refer to the following: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-30 20:36:37] |
Sierra_Chart Engineering - Posts: 14423 |
We will see what we can do but there is a new ACSIL function we are working on to set the height of chart regions.
